Old 10-09-2004, 11:44 PM   #1
edseb's Avatar
Default Removing anodization?
I've heard that you can remove the colors of anodization from aluminum by spraying oven cleaner and scrubbinbg it off. I tried it and it didn't work. Maybe I'm using the wrong brand, I tried Eazy Off lemon scented foam spray. I also tried paint remover, but that didn't work thanks to the helpful people at Home Depot. Anyone have an easy solution?
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 10-10-2004, 12:09 AM   #2
Default I did this about 15 years ago.
I used a heavy duty oven cleaner and some steelwool. It took several spray coats and some hard scrubbing. Afterwards I used aluminum polish. These days oven cleaner may not be as harsh. Good luck.
Nightbreed is offline   Reply With Quote
Old 10-10-2004, 12:13 AM   #3
edseb's Avatar
15 years ago? Jeese, I bet those chemicals would get you thrown in jail nowadays. Anyway, thanks for the tip. There's got to be a way.
Carl Hyndman
Old 10-10-2004, 01:33 AM   #4
j240z's Avatar
You have to use the Outdoor breeze scent instead of the lemon.
OK I'm kidding. The trick is to let it soak. I use liquid draino instead. MIx a small amount 50/50 with water and let it soak. You'll see vigorous bubbling once the color begins to come off. Then just rinse, dry, polish!
Remember ventilation and safety glasses!
j240z is offline   Reply With Quote
Old 10-10-2004, 03:58 AM   #5
Default Of course you will lose the corrosion resistance.
Anodizing is not just about coloring aluminum. It provides a corrosion resistant finish and increases the surface hardness. You will go from a tough, maintenance free surface to one that requires polishing to keep shiny.
Disaster is offline   Reply With Quote
Old 10-10-2004, 08:03 AM   #6
The old Easy Off in the yellow can works. Just did some parts this week. Don't leave it on too long, it wil actually eat aluminum.
Ted Flack is offline   Reply With Quote
Old 10-10-2004, 08:48 AM   #7
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I just got through removing the anodizing from 3 cars worth of aluminum... not fun. Get EZ off heavy duty, spray it in a cheap pan or something, and let the pieces sit in it. I found that the anodizing strips off different parts at different rates, so be careful because it will discolor the aluminum if you let it sit too long.
Old 10-10-2004, 10:17 PM   #8
edseb's Avatar
Thanks. I don't mind it kind of dull. Has an industrial look, better than purple.
Carl Hyndman
Old 10-10-2004, 10:38 PM   #9
NVisible's Avatar
oxy clean faded the anodizing on some of my GPM a-arms. it may strip it off totally if you actually tried to remove it. (i just let it dry)
NVisible is offline   Reply With Quote
Old 10-13-2004, 12:56 PM   #10
edseb's Avatar
I'll try that too if the EZ Off doesn't work that well. Anyone else?
Carl Hyndman
Old 10-13-2004, 02:13 PM   #11
j240z's Avatar
Liquid draino
Old 10-13-2004, 04:20 PM   #12
I just sand blasted some of my parts. They will look like this (shock caps) and (motor plate)
shortygy is offline   Reply With Quote
Old 10-13-2004, 04:32 PM   #13
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
that sand blast looks like it came out good
Javen13 is offline   Reply With Quote
Old 10-13-2004, 04:37 PM   #14
s2
s2's Avatar
tutorial
s2 is offline   Reply With Quote
Old 10-13-2004, 04:45 PM   #15
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Shortguy what type of media did you use for blasting ?
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
removing tire from rim lachlan90 Nitro On-Road 10 02-08-2004 03:28 PM
removing tire from rim lachlan90 Electric On-Road 8 01-20-2004 02:27 AM
Removing CA Calvin Ng Electric On-Road 1 08-03-2003 11:54 PM
Removing Anodization ZER01 Electric On-Road 8 02-01-2003 12:37 PM
Removing of E-Clip? F&K Singapore R/C Racers 6 01-29-2002 08:49 AM
