GEAR diff or BALL diff ?
#61
Improvements in cars and tires which increase traction make gear diff use possible. And better materials make them reliable.
#62
VernDog-
If you use high quality ceramic diff balls then this should not be a problem, but I can tell you that you probably won't like the ball diff up front. I was doing some testing and tried it the other day. It helped very little a corner entry and was much slower coming out. I would rather the car plow a little coming in and pull coming out. I have tried 500K up front and like the way it felt, but all of this as on carpet. I have never tried Putty, and making the spec r gear diff fit in the TC6 is no easy task with simply a dremel. I know you have access to the right equipment so it will be easier for you. I am really happy with the spool/Ball diff on carpet and will run that until the AE version of the gear diff get released.
I'm with you on waiting for the AE version gear diff, and it wont take much to build a tight ball diff with some slick voodoo tar of some type and see.
#63
some people may see a gear diff as going backwards,but the ball diff came in when we were using brushed motors and nimh batteries.
the efficiency and slight weight loss of a ball diff is not such a important factor now with brushless and lipo,were as strength and less maintenance of a gear diff is probably making them more popular again.
just a thought
just a thought
#64
Yoko also did a damn good job designing it, the cups have some coating on them as hard as hell, it took no fine tuning for the build, just fill and go, and it's butter smooth...
If you compare the rooting around you do with a ball diff, to what I had to do with the yoko diff, it's so not a content between the two.
#65
Anyone used Silly Putty as an alternative? It is sold everywhere and usually for under $2 bucks.
http://en.wikipedia.org/wiki/Silly_Putty
#66
Furthermore, Anti-wear grease seems to have a funky property that works well in a tight front ball diff application. In suspension damping terms, it seems to have soft slow bump damping but hard fast bump damping. Even though the diff is very tight, rotating it slowly will still allow reasonable diff action. But if you try to apply a quick shock load to the diff (i.e., rotate it very quickly and suddenly), the grease seems to 'bind/pack up' and become more resistant to movement.
That said, I prefer the 100% smoothness feel of a ball diff though, so thanks for this bit of info! I'm gonna try some and see if I can get that tightening effect without buying a new diff.
#69
just a thought
just a thought
#71
