Turbo 35 GFX Smoking... Help! >
Old 10-08-2004, 08:19 PM
Default Turbo 35 GFX Smoking... Help!
Hi,
I have a brand new Turbo 35 GFX. I have been out of racing for about ten years. I received my first "new" stock motor today and tried it on my motor run function. I tried it at 5v and it was pulling close to 20 amps (my old green machine pulls about 4 amps) Does this sound right? The motor was really screaming and seemed fine. It had probably been running less than a minute. All of the sudden I hear a pop and smoke starts billowing out of the Turbo 35. The motor kept running and the unit continued to function, but I disconnected it right away.
I'm pretty sure I need to send it in, but what happened? The fuses were not blown. Did I roast it running a stock motor at 5v? I guess things have changed since I've been out of racing for so long... Thanks for any help.
James
Yankey is offline
Old 10-08-2004, 08:24 PM
pink pac man's Avatar
it could have done what my tv did if you havent used it for a while and a spider climnes through the air holes and you using it for a while then the spider walkes onto some thing and shorts it out blowing it up
pink pac man is offline
Old 10-08-2004, 08:25 PM
Matt Howard's Avatar
Uh...I would send it in ASAP. If the fuses haven't blown and you have smoke billowing out of it there is a definite problem. You didn't do anything wrong by running your motor at 5V, and if the motor pulls too many amps you're supposed to get an error message that say's something like "Amps too high" on your screen.
Matt Howard is offline
Old 10-08-2004, 09:09 PM
fatdoggy's Avatar
Yes it will cutoff the power to the motor if it's pulling too many amps. It sounds like the motor was getting 12v if it was really screaming. I've seen this happen on a gfx before, unplugging it/re-setting it fixed the problem. I think it's actually 20 amps that the gfx cuts off at. Send it in asap.
fatdoggy is offline
Old 10-08-2004, 10:29 PM
Registered User
ritchie's Avatar
while were talking gfx, i just got a brand new one. i'm not real crazy about the directions. seems they could have been more instuctive, anyway, i was reading in one on the mags that did a review and the author talked about "reving" up a motor using the dial to adjust voltage, mine doesn't adjust with motor running only before . is it suppose to be adjustable with motor running or did i read it wrong??
ritchie is offline
Old 10-09-2004, 06:21 AM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
Sounds like a blown fet in the charger...
20A from a stock...WOW....
Sounds like the motor has issues also...
www.competitionelectronics.com
For repair on any Competition Electronics product ship to the following address
Att: Service
3469 Precision Dr.
Rockford, IL 61109
Include a brief note explaining the problem along with a return street address (no PO Box) and a daytime phone number. No RA# is required. We will call you with the charges when repairs are finished. Payment can be made with a Visa, Master Card or you can send us a check or money order. Include a copy of the sale receipt for warranty repairs. Normal turn-around time is 5 working days.
Some problems may be due to an operating consideration that needs further explanation. If you have any questions about your product call us between 8:00-4:00 Monday thru Friday central time at 815-874-8001 FAX 815-874-8181.
Tres is offline
Old 10-09-2004, 06:30 AM
onebeatuptc3's Avatar
one thing, check to make sure the fuses used are the correct fuses also, and not ones of a higher amperage. It could have drawn too high and the higher amp fuses didnt pop.
onebeatuptc3 is offline
Old 10-09-2004, 10:00 AM
JayBee's Avatar
Trader Rating: 31 (100%+)
Congratulations!!
- jaYBee
JayBee is offline
Old 10-09-2004, 10:06 AM
Registered User
ritchie's Avatar
TRES. did you miss this question.
[i]Originally posted by ritchie [/
ritchie is offline
Old 10-09-2004, 10:15 AM
X2
X2's Avatar
Default GFX smoking?
I have never heard of this, what does it smoke? roll ups, cigars?
X2 is offline
Old 10-10-2004, 06:02 AM
Tres's Avatar
ritchie: it stated he heard a pop and puff of smoke....
With a blown FET, the CE chargers tend to send line voltage through the leads if this happens...
12V....
But, 20A on a stock motor,
WAY to high....
Tres is offline
Old 10-10-2004, 06:09 AM
if you send the charger in , also send the motor with it. CE customer service has been excellent for me. They do not overcharge you. they fix it. the problems i have had with my chargers has been user related LOL.
baih is offline
Old 10-10-2004, 08:28 AM
Fatboy Joe's Avatar
Same ting happened to me today, but I was discharging my pack with 8.3V left in it at 30amps. I saw some smoke being blown out of the vents on the side. I checked the fuses and some how melted a bit, they are 20amp fuses, and wondering why it didn't blow up. Is my GFX T35 busted already?
Fatboy Joe is offline
Old 10-10-2004, 08:56 AM
The wierd thing for me is that my old stock motor and an old 12T modified ran normally...so I'm not sure about the 12 volt theory. I ran the "20 amp" stock motor for about six races (after it blew up the GFX) and it ran fine.
I did blow a fuse before. It was the one for the power supply (the single one). One of the leads slipped off at the power supply while a battery was charging. I replaced it with a 15 amp one because I did not have another 20 at the time. Maybe this is why I had the problem... Thanks for the help.
James
Yankey is offline
Old 10-10-2004, 12:59 PM
i am beginning to wonder if you had the motor hooked up backwards.
baih is offline
