Spur gears
Old 06-12-2011, 12:17 PM
duggyload's Avatar
Default Spur gears
Could somebody explain the theory of bigger or smaller spur gears run at the same rollout
duggyload is offline
Old 06-12-2011, 01:18 PM
duggyload's Avatar
Ok found it in another thread
http://www.rctech.net/forum/electric...ller-spur.html
http://www.rctech.net/forum/electric...spur-gear.html
Old 06-12-2011, 01:59 PM
I asked a similar question once...
If you do the math, it doesn't matter.
http://www.rctech.net/forum/rookie-z...-question.html
Coach-Z is offline
Old 06-12-2011, 03:11 PM
Weight distribution.
chris_dono is offline
Old 06-12-2011, 05:39 PM
I think every little thing matter in this hobby, even the spur gear manufacturer!!! I can get through a six minute main and only burn 2200mah out of my Tp 40c lipos with my 3.5R hirosaka geared and Acer bearing only tc4 in a 8scale track ! I could not do that when I was using Ae bearings and kimbrough gears!!!
bertrandsv87 is offline
