Old 06-10-2011, 06:02 PM   #1
Trader Rating: 55 (100%+)
Default LRP X12 blinky question
Touring Car 17.5?--What timing insert and gear are being used on high bite, fairly large flowing asphalt track? More gear less timing or more timing less gear? I wont have but 1 day of testing at this track before race. So im hoping to get something close to work with.
Jamison R is offline   Reply With Quote
Old 06-11-2011, 12:58 AM   #2
i always use 4 dot on lrp motor ( lrp recommand it )
They like to run with a low FDR and 50 of timing
On my 10.5 with tekin
TP 2 expo
boost 40 [email protected] rpm
Turbo 10 0.3 sec and ramp 1 ( soft )
FDR around 6.6
Manson is offline   Reply With Quote
Old 06-11-2011, 02:36 AM   #3
Default blinky mode in 1/12th
using the same guide lines in 1/12th blinky X12 10.5 use 2 dot and 25% higher rollout than you would use for boosted.This seems to be the perfect combination.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 06-11-2011, 03:49 AM   #4
any 17.5 TC Blinky set up advise? Using tekin RS esc
Old 06-11-2011, 05:48 PM   #5
guess not
Old 06-11-2011, 07:40 PM   #6
Xpress's Avatar
4 dot insert start @ 4.0 fdr.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-12-2011, 02:27 AM   #7
Thank you
LRP SXX StockSpec V2 ESC andrew-01 Electric On-Road 1179 02-01-2015 10:31 AM
