Best and strongest cooling fan >
Like Tree10Likes
Old 03-07-2019, 12:13 AM
  #346
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Originally Posted by Pinkyverma View Post
If you are looking best and strongest ceiling fan then Hover is the best option for you.
You mean Hoover right?
And Hoover make vacuum cleaners don't they?
nexxus is offline
Old 03-07-2019, 12:32 AM
  #347
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
nexxus I think this is what he was getting at: Hover? with DC Motor
lol
I think he might have misread this thread.
1/8 IC Fan is offline
Old 03-07-2019, 07:26 AM
  #348
Becuase it's worth mentioning... 30mm EDF's are a thing. And for $30, you could have ~a freaking jet~ cooling your car. https://hobbyking.com/en_us/edf30-wi...assembled.html
DavidNERODease likes this.
Nerobro is offline
Old 03-07-2019, 07:35 AM
  #349
LOL, this would be hilarious and legal?
DavidNERODease is offline
Old 03-07-2019, 07:46 AM
  #350
I believe it would be legal. I've seen no rules about fans beyond like... 30 and 40mm... so.. this is 30mm.
Honestly, unless you have a proper exhaust duct, you're not gonna get much from it.
That fan won't take more than a couple amps to run, and if you "poorly calibrated" the ESC endpoints, you could use the same signal as from your main ESC. alternativlely, hook it up to your third channel, and do some mixing. Idle at 20%, crank it to 100% anytime the throttle is something other than idle....
Nerobro is offline
Old 03-07-2019, 08:55 AM
  #351
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
Marcos.J is offline
Old 03-07-2019, 08:56 AM
  #352
Super Moderator
Marcos.J's Avatar
Single no larger than 30mm fan is what the rule book states unless it has changed
Marcos.J is offline
Old 03-07-2019, 09:34 AM
  #353
I just ordered two sets of 30mm fans. Slowboat... but we'll see.
So... 13 amp fan. 14,000kv. [email protected], [email protected]
Yes, that's grams of thrust.
Nerobro is offline
Old 03-07-2019, 10:57 AM
  #354
6.1.13 Cooling holes: Bodies for on-road fuel-powered cars (other than touring vehicle bodies) may have up to 1/3 of the windshield cut out. Bodies used on off-road fuelpowered cars may have up to 1/2 the windshield cut out. For touring vehicle windshields, one cooling opening is permitted, limited to a maximum of 60mm in any direction.
Uh... Cooling fan downforce "can be a thing"... BWAHAHAHAHAHAHAHAHAAHAHAH
Originally Posted by -Potassium
nerobro's gunna violate the "don't make us make more rules" rule.
Nerobro is offline
Old 03-27-2019, 09:05 PM
  #355
silden's Avatar
The best Cooling Fan delivered only sub par performance when not installed in the correct distance to the chassis.
Therefore so called Fan Shroud getting more and more popular in the industry.
They help to channel the airflow to the motor to improve the temperatures throughout the run.
I believe that the topic of Cooling should change from what is the best Fan to what ist the best combination of Cooling Fan and Fan Shroud.
Nerobro likes this.
silden is offline
Old 03-28-2019, 07:25 AM
  #356
"any duct" :-) My little .2 watt fan cools my 21.5 quite well. But i'm looking to move up to a "watt or two" fan so it's not even warm coming off the track.
Heh. Yey, rules. In the current incarnation of the ROAR rules, they only mention one fan, but do not disallow other fans. At least, that I can find.
So... the ROAR motor cooling rule is broken. It states you're not allowed any heatsink that's not made of cast aluminum. ... I've literally never seen an cast aluminum heatsink used on a r/c car. they're all, at worst, extruded, and most seem to be fully machined. On the motor they allow a "standard" 30mm fan. But they don't define what standard is. Is a WTF fan that draws 3amps a standard fan, or the .2 amp thing I got off of amazon a standard fan?
And in ROAR there is no rule for the ESC fan. In fact, there's no rules I can find about fans......... Where did I find the two fan rule? I'll go searching for that again.
The roar rules kinda open things up to the point of ridiculousness. :-/
Nerobro is offline
Old 03-28-2019, 08:32 AM
  #357
Trader Rating: 16 (100%+)
OK, I dare someone to mount two of these Jets in the back of their car like the Chapparal 2J.
glennhl is offline
Old 03-28-2019, 08:36 AM
  #358
I've always liked the WTF fans, but I just did mount up a R1 fan and it's even better. As far as ducts? Just be careful how you mount the ducting. I've seen some people mount the duct up against the motor. If there are no holes in the motor, then you deadhead the fan and it will flow zero air. I mounted a duct and found my motor came off hotter than without a duct.
silden likes this.
glennhl is offline
Old 03-28-2019, 09:15 AM
  #359
I feel like that might really piss people off. Also air path routing from the esc and motor to the back of the car.. would be hard.
glennhl likes this.
Nerobro is offline
Old 03-28-2019, 11:23 PM
  #360
silden's Avatar
You are correct the FanShroud shouldn't be mounted against the Motor, when the motor hasn't enough openings to let the air through.
The motor temperatures sometime seem to be higher with a fan shroud. This is due to the air reaches deeper in to the can and transported out.
We tested this before releasing our own shrouds and it showed that the coils and rotor had a significant lower temperature than with the Fan only.
This bears in mind that is has been mounted correctly in the first place.
silden is offline
