Sanyo's new cells >
Sanyo's new cells
Sanyo's new cells
Old 10-06-2004, 02:10 PM
Default Sanyo's new cells
Does any one have any info on the "new" Sanyo 3600 cells. Are they in new shrink? Date codes? Are they avalible in the USA? Are there any testings avalible? Not that I wouldn't believe what Trinity says. I'm thinking about new cells. HAYWYRE
haywyre is offline
Old 10-06-2004, 02:30 PM
AdrianM's Avatar
The "new" RC 3600 is the old cell with tweaked chemistry and construction not a new cell
Same shrink was before
No date code info
They are not available in the US right now. Only Orion and GM have them in Europe and Yokomo in Japan.
All 10 drivers at the Last Japanese Nats used RC3600's...not one GP cell in the main. How's that for testing.
These cells will not hit the market until after the worlds. Expect them to cost ~25% more than GP3300 packs. They will be faster so you will have to get them no matter how expensive they are.
Be prepared to do do this all over again in ~4 months when GP's answer to the RC3600 comes out
AdrianM is offline
Old 10-06-2004, 03:20 PM
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
The battery wars begin again!
Jon Kerr is offline
Old 10-06-2004, 03:22 PM
I thought they used the 3600 just so they could put more power down without worrying about dumping before the end of the race.
mtc3od is offline
Old 10-06-2004, 03:44 PM
Company Representative
Trader Rating: 15 (100%+)
The current 3300 is more like a 3500 in most cases.
340 seconds @35 amps works out to 3300mah.
most cells these days that we are seeing is in the 350-365 range or 3500mah.
Adrian, We heard that they used the Sanyo cell because the higher resistance (higher AIR) made the 12th cars easier to drive at Yatabe with low turn motors.
Its hard to justify matching cells that are no better then what is offered now at a lower price.
Korgae is offline
Old 10-06-2004, 04:12 PM
JimmyMac's Avatar
I thought they only used the RC3600 batteries is because
1. It was 1/12th scale "Mod" and
2. It's an 8 minute run.
If it were stock, it would be a different story. That was my understanding. I dunno, not unless if you are talking about a whole new Sanyo 3600 cell.
The 3600's were taller than the GP3300's. But they were lighter.
They were recommended for offroad and pan cars. But not for Touring.
Of course maybe Adrian knows something we don't.. hehe..
JimmyMac is offline
Old 10-06-2004, 04:29 PM
gee-dub's Avatar
i wonder if the organizations will step up to put cost and technology limitations on batteries.
kind of ironic that we regulate just about every facet of a motor, but when it comes to batteries we do little more than size and composition. of course on the flip side, the vast majority of tracks don't follow the letter of the law anyway.
gee-dub is offline
Old 10-06-2004, 05:57 PM
Fire's Avatar
i guess it is hard to put limits on batts as size is the only thing that is obvious
Fire is offline
Old 10-06-2004, 06:02 PM
Trader Rating: 70 (100%+)
The 2 packs I have are slower in stock.
They have about 25-30 seconds MORE runtime than my GPs but less voltage and alot higher IR.
They are ok in mod but I wont be using them in stock anytime soon.(NOTE) they were about $20.00 more PER pack as well.
Korgae is right.If GP gets their runtimes back up they are still the dominate cell and alot cheaper to the public even with their small price increase.Plus better performing.
Sanyo 3600's were used due to at the time GP's only showing about 420-430 runtime at 30 where as the 3600's were showing 450-465 runtime.That lil bit was helping and the Ir's were smoother.
My cousin is stationed over there and was in the Pits talking with racers on why they were running 3600's.
I hope this info helps.
TexRacer is offline
Old 10-07-2004, 06:18 AM
AdrianM's Avatar
Tex - You and everyone else has the old batch of 3600's. The new stuff is COMPLETELY diffrent. Low IR, High Voltage, High run time. We have guys running these cells in Europe. We know first hand about this.
AdrianM is offline
Old 10-07-2004, 06:24 AM
Jeff Werner's Avatar
Trader Rating: 21 (100%+)
Are your drivers reporting how they compare to the GP's that they had been running? I am like everyone else kinda got ue to the great price/performance of the GP's.
Jeff
Jeff Werner is offline
Old 10-07-2004, 07:07 AM
ddesros2's Avatar
In stock and 19T classes the 3600 cells will provide no advantage. On a local level there is no need to run out and get the 3600 cells. I'm sticking with my 3300 GP's and I will still win races over guys with 3600's (because I practice )
ddesros2 is offline
Old 10-07-2004, 07:13 AM
Mr. Shookie's Avatar
No date code info
You are incorrect about them being available in the US. Integy has them for sale, matched and ready to go. they are not premade packs so you will have to solder, but the numbers were great on the cells I got from them. like 650 sec and they were 1.174 volts which aren't the best but this pack I got last forever. Now for racing, I wouldn't bother unless your track is going to make the main 6+ minutes then go for them. I use mine mainly for practice and set-up you get the most of your practice runs and you can get much more data from your lap times that way. I have run these for 8 minutes before lap times showed any serious drop. I think it is time to increase the MAINS time to 7 minutes, I'm ready ARE YOU? LOL
Mr. Shookie is offline
Old 10-07-2004, 07:17 AM
sosidge's Avatar
The fundamental problem with this argument is that the newbies who get a car for christmas will only get a 1500 pack or similar - they haven't got a hope of making a 7 minute race (some struggle to do 5!). It's disheartening enough that they are half the speed of the top racers - but if they never fininshed a race, they would be even more turned off.
EDIT: Just checked Integy's page, they must be 1.174 at 30A, because they are getting 1.24+ at 20A - that's pretty impressive numbers...
sosidge is offline
Old 10-07-2004, 07:24 AM
Matt Howard's Avatar
let's go race nitro. At least when GP releases a new cell all the matchers have a chance to get them at the same time, more or less. Sanyo always seems so secretive whenever they release something new that actually works. Maybe it has something to do with trinity being the only U.S. importer, I don't know.
Matt Howard is offline
