reedy 19t spec quad mag setup >
Old 10-06-2004, 04:26 AM
Default reedy 19t spec quad mag setup
i am going to start running on a small flat carpet oval, i just bought this motor. what would be the best setup as far as brushes springs for my TC3? thanks
Aadolf is offline
Old 10-06-2004, 04:33 AM
pink pac man's Avatar
i use atlas mh7-079 brushes with the standard springs but cos my track changes i have to change stuff but i only got my reedy quad mag yesterday its fast iznt it
pink pac man is offline
Old 10-06-2004, 05:52 AM
Team Duratrax's Avatar
Ive got one ordered at the moment how fast are they?
-Sean
Team Duratrax is offline
Old 10-06-2004, 06:06 AM
JDXray's Avatar
these are pretty fast motors.
I currently run Reedy 767 + with hole and 766 - with hole. With the springs that come on them. ( i think its copper i might be wrong) I might switch to purple all around. Or Red and Purple.
I am also interested in setups for this motor too.
Jon
JDXray is offline
Old 10-06-2004, 08:03 AM
Regional Moderator
UnderDaHill's Avatar
For sedan racing try the following:
767+ w/ hole and Purple Trinity Spring
767- w/ hole and Red Trinity Spring
If you have a sonic fiddle stick use 7.0+ and 6.5- spring tensions.
Align brush hoods with an alignment bar strait accross and centered with the bearings. I use a Big Jim alignment bar which has a bar that goes through both hoods and a pin that goes throught the bearings and the bar.
Do NOT adjust the hoods individualy to compensate for brush shift.
Center the armature (as you should with all motors) in the magnetic field.
Break in the brushes (so the serrations are shiny across the entire brush face).
Then clean the comm with a comm stick and spray out the motor and relube.
You should have one fast motor now. Remember to gear up 4-5 teeth from a Chameleon 2 if that is what you have been using.
UnderDaHill is offline
Old 10-06-2004, 08:19 AM
Jack Smash's Avatar
Trader Rating: 33 (100%+)
Just curious, why would you not align to accomodate for brush shift?
Jack Smash is offline
Old 10-06-2004, 08:29 AM
i was using a trinity 27T stock motor what spur and pinion combo should i use for a small flat oval carpet track? or what would u suggest.
Aadolf is offline
Old 10-06-2004, 08:58 AM
Silver Cup's Avatar
Thumbs up Quad Mag
-Sean
They are really fast. You'll be able to gear it a few teeth higher on the pinion than you would think.There is a local company up here in Washington State that makes a hand wound Quad Mag Motor using the REEDY can as well. They are called Team Br00d..........Send PM to EddieO or an email to this address if your interested. [email protected]
I am not sure if there website is done but it is www.teambr00d.com
Silver Cup is offline
Old 10-06-2004, 09:06 AM
ottoman's Avatar
The theory is that by aligning this way you will reduce the timing slightly and these motors run better with a little less than the 24 degree locked timing it comes with.... does it help? Maybe slightly
ottoman is offline
Old 10-06-2004, 09:39 AM
Regional Moderator
The Reedy Quad magnet,like the quad magnet mods from reedy, generates slightly more power with less timing than 24. Since the spec motor is locked at 24 the brush shift will retard the timing a smidge and give you slightly more power. I think this is about the only motor that I would suggest not aligning the hoods to compensate for brush shift.
All this information came off the Big Jim forum on rccars website.
Old 10-06-2004, 09:41 AM
Regional Moderator
Ooops.... what ottoman said.
Oh.. and Team Br00d makes some very good motors. Put one of his hand wound 19t arms in your reedy quad mag spec motor and you will have some serious power. Of coarse that's only if your track rules allow you to put a hand wound arm in your motor for the 19t class.
Old 10-07-2004, 03:09 AM
i was using a trinity 27T stock motor what spur and pinion combo should i use for a small flat oval carpet track? or what would u suggest. i'm not really sure what i have on there atm.
Aadolf is offline
