Old 06-06-2011, 04:41 PM   #1
Default Best 13.5t Motor?
Already got myself a speedpassion 13.5t in my Mi4 with a hobbywing xtreme stock. Have now got an xray t3 11 on order with another xtreme esc.
Should I stick with the speedpassion or is there something quicker out there? Was looking at the GM or Nosram range.
Mb3195 is offline   Reply With Quote
Old 06-07-2011, 05:20 AM   #2
The SpeedPassion is great I love that the cables are connected to the back of the motor, then there's space for a fan without resoldering the cables.
Of course there may be faster stuff out there, but the differences will be small.
By the way, you don't have the best ESC on the market, so you can start there if you REALLY want power
Skynet is offline   Reply With Quote
Old 06-07-2011, 06:38 AM   #3
Trader Rating: 17 (100%+)
I have a Speed Passion, Duo 3 and an LRP X12. They all perform well with the SP probably the easiest to find the sweet spot and the lowest temps.
only just got the X12 and it seems wicked fast, but still trying to find the right settings to keep temps down
Also, nothing wrong with Extreme stock, thats what I am using
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Old 06-07-2011, 10:53 AM   #4
Might be a question for the rookie section, but here goes...
What makes the ESC the part in the chain that effects power output the most? I would assume that the motor would be the biggest "difference maker".
Xray T2'008 - Robitronic 13.5 Turn Brushless - Excelorin ESC
Losi XXX-S - Traxxas (550 can) 12 Turn Brushed - GM V3r ECS
Traxxas Rustler - Arrowind 13 Turn Brushless - Arrowind ESC
Losi Mini Desert Truck - Reedy 19 Turn Brushed - Traxxas XL-5 ESC
Losi Aftershock - Hobbyking 1550 1/8 Brushless - Trackstar 150A ESC
Coach-Z is offline   Reply With Quote
Old 06-07-2011, 11:17 AM   #5
Regional Moderator
CarbonJoe's Avatar
As far as spec or "non-boost" goes, the motor is most likely more important than the ESC. Once you allow boost, then the ESC matters more than the motor, since you can tweak the ESC to work around limitations in the motor.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 06-07-2011, 04:36 PM   #6
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Can't go wrong with any of those, but it you like the Speed Passion stuff. Why not stick with it? Speed Passion has some new stuff in the works. Like new sensor boards with more timing for V3 motors that will be awesome in the non boost classes.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Best 13.5T Brushless Motor/ESC for 1/10 2WD? Armaan Electric Off-Road 17 06-29-2014 04:52 AM
Best 13.5T motor, which 1? mac853 Electric On-Road 7 11-19-2009 03:29 PM
THE BEST 13.5? Double D Donuts Electric On-Road 22 10-07-2009 12:38 PM
Best 13.5 motor? orzel24 Electric On-Road 21 08-15-2009 09:13 PM
