Old 06-05-2011, 07:04 AM   #1
RsageD's Avatar
Default tf5 bush holder set
anyone can explain what are these for and usage? sorry for the noob question. thanks.
http://www.imcmodels.gr/1/97/2403.xhtml
RsageD is offline   Reply With Quote
Old 06-05-2011, 08:03 AM   #2
Registered User
Send a message via MSN to Vasco C
They are used in the suspension blocks. You can click'em in and they'll hold the pin that goes trough your wishbone. With the different letters you can create different width's of wishbone settings.
Vasco C is offline   Reply With Quote
Old 06-05-2011, 09:13 AM   #3
RsageD's Avatar
Thanks but which is the wishbone? I am so sorry and i know this can be quite irritating to answer noob questions. Mine is a RTR tf5. Can i use them?
Old 06-05-2011, 01:13 PM   #4
Registered User
Thats okay, we're here to help
A wishbone is the suspension arm, looks something like this:
http://www.the-border.com/image.php?type=T&id=35988
You can only use the holders when the car supports these suspension holders:
http://rcspecial.com/news/wp-content...f604051012.jpg
Your car doesn't have those and is therefore not compatible with those bushes.. Hope this helps you out.
Old 06-05-2011, 09:25 PM   #5
RsageD's Avatar
It does! That means i need to buy the Aluminum suspension holder and i can control the toe in tight? angle of the tire's? thanks man!
Old 06-06-2011, 09:52 AM   #6
Registered User
Yep it does, I'm not sure though if the aluminuim suspensionholders are compatible with your car.. maybe you should email Kyosho as I don't know anything about the TF5 rtr.. But I think it will work just fine!
With those options installed you can indeed change the toe in/out of your car.
Old 06-06-2011, 08:28 PM   #7
RsageD's Avatar
Thanks alot for your reply Vasco C. Appreciate it!
