Lowest Resistance Wire Connectors?
I was curious to know what everyone thinks is the lowest resistance battery/motor connection.
I currently solder my ESC wires to the battery using Deans bars (bent in an L shape), but i'm getting tired of lugging around my iron. I've heard that as you continually solder and desolder the wires you can add more resistance to the wire since the solder moves up the wire, not to mention the additional unnecessary heat to the batteries or other electrics.
I was considering soldering on a small eyeloop to the battery wires and tapping a small hole on the deans connector so I could screw down the eyeloop. This solution could perhaps provide less resistance, more convenience for battery changes, and less tools to bring to the track (or at least set-up).
Does anyone know if a clean connection (solderless) yet one that is firmly held into place is better than a soldered connection?
Also, Yes I've seen and used both Deans and Plug/Socket style connectors. I use saddle packs so using Deans connectors make the pack kinda gangly.....
Thanks for the reponse.
Deans have the lowest resistance for connectors, but that's still more than direct soldering.
It is possible to make lower resistance connections without soldering, but it isn't easy. Considering that there are already 12 soldered connections in a battery anyway, two contact connections are not going to make a huge difference. Your loop connection idea is pretty good. You have to keep both surfaces clean and when they are bolted together they need to be tight. The use of Belville (I always though they were bevel) washers may help to keep things tight through heat cycling. Some of the motor connectors used on brushless motors are very good connectors and are better than deans. They are also separate from eachother so you will be able to use them on saddle packs.
Look at this
http://www.schulze-elektronik-gmbh.de/guide/gstv-e.pdf
The connector at the top of that page can be used without the shells. I have seen those plugs soldered directly to the battery terminals.
Look at this
Get some corrally plugs they are the best for low restance connections. Unless you direct solder.
Connector Resistance (ohms)
Tamiya / JST / Kyosho 1.2
Deans 0.55
Powerpole 0.75
Corally / Orion 0.75
http://www.schumacher.clara.net/cooling.htm
A bad direct solder connection will have a higher resistance than any of the connectors shown above
I'd like to wager that connector resistance never did cost anyone the World Championship
I agree, a cold solder joint coming off could cost you the race!
just a thought....
V=I*R
deans connector R=0.0009ohms
Voltage(drop @ 30A) = 30A*0.0009ohms = 0.027V
Thats the same difference between a 1.178v pack and a 1.183 pack.....
People pay extra $20 for that same amount of difference when buying cells.......
But then again...i could have worked it out wrong.....
btw, im on both sides here....
V=I*R
From measurements that I have made at work, a good solder joint has about 150 micro ohms of resistance (0.000150). There are 12 joints on the battery itself including the tabs soldered on to the end cells to make solder tabs. That is 0.0018 ohms for just the battery connections. The best connection is made without solder. So to take full advantage of your 1.180 cells you should not use battery bars. Just some food for thought.
FYI the chart found on this page
Should probably have resistance measured in milliohms and not ohms. If it were ohms, deans would melt with 20 amps flowing. 20^2 * 0.55 = 220 Watts!!!
i use deans on the motor and corralys on the b82rez and im always in the top 3 and every1 else uses solder conection ............................just use whatevers easyest exept for tamiya connectors or venom connectors
Trinity R-Minus style connectors are my personal favorite (easy to use with saddle cars too)
Deans connectors are hands down the best. I would rather have 4 good solder joints on my connectors than a solder joint that has been soldered and unsoldered dozens of times. Plus if my pack happens to pull my connector apart. I probably want to stop because something would be wrong. I do solder on my 12th scale tho for weight and room.
Hara could use tamiya plugs and kick everyones butt............. but does that mean tamiya plugs are better and are of least resistance??
