Battery temp (after charging) >
Old 10-04-2004, 09:13 PM
ajg
Registered User
ajg's Avatar
Default Battery temp (after charging)
If I charge my cells on about half what they could be charged at, (I charge them at 3 amps now), will they get hot after I fully charge them?
ajg is offline
Old 10-04-2004, 11:22 PM
Cole Trickle's Avatar
Are you getting paid by someone for advertising all that in your signature ? Lots of info, but not what's needed.... Which charger and which batteries?
Cole Trickle is offline
Old 10-05-2004, 10:35 AM
Chill Will's Avatar
Your batteries still should get warm. It's just going to take a long time to charge. You should have more runtime charging that low but the voltage will be low.
Chill Will is offline
Old 10-05-2004, 11:01 AM
rtypec's Avatar
They should be warm to very warm.
According to one of his "threads" ajg uses cp-1300 or cp-1700 cells to power his project cars...and he wants to verify that his cool batteries are fully charged.
ajg's "68 mph micro" thread
ajg's "Fastest 1/18th" thread
There are a number of ajg fantasy vehicle speed threads out there
rtypec is offline
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
ajg
I use a eagle cdc to charge & my batts come of around the 130-140 mark,they are charged straight from flat with no probs what so ever,charge are 5.5 amps,3mvc,roughly about 45 mins to charge
MR JOLLY is offline
Old 10-05-2004, 03:03 PM
crimson eagle's Avatar
Chill Will,
I heard the theory of cells having more runtime with a lower charge current some time ago. After doin tests at 4 amps and 6 amps I found very little difference in the numbers when discharging at 30A.
Chris.
crimson eagle is offline
Old 10-06-2004, 12:03 AM
MR JOLLY's Avatar
When the first 3000,3300 came out i used to charge at 3.5-4 amps, now i charge at 5.5 & they are alot better runtime & punchyness, aleast i don`t have to wait a long time to charge used take nearly a hour to charge at 3 amps
MR JOLLY is offline
Old 10-10-2004, 04:33 AM
pink pac man's Avatar
i charge at 3 amps and i cant pick my batts up .........i cant touch em at all
pink pac man is offline
Old 10-10-2004, 04:46 AM
JDXray's Avatar
Thats not good. i charge my 3300 at 6amps and there warm/hot but i can still pick them up.
JDXray is offline
Old 10-10-2004, 04:58 AM
i have a $60 ansmann charger is dodgy as...............and when i charge it sits at 40% then goes straight to 100% it pisses me off ....................if i charge like this will i have any batts left buy chrissy im gonna get a lrp pulsar 2 for chrismas
Old 10-10-2004, 05:28 AM
MrRolla's Avatar
Trader Rating: 30 (100%+)
I charge at 6 amps and my cells barely get warm, thats probably because i have 2 12v computer fans in my table and i charge the cells on them..
It works great
MrRolla is offline
Old 10-10-2004, 05:42 AM
i also use 2 12v computer fan when im at th races to mension it they dont get hot at the races but they do at home ...................................races=fans home=no fans
Old 10-10-2004, 05:50 AM
X2
X2's Avatar
It works great
You still want them warm after charging, just not too hot. If they are warm they tend to have lower IR and more punch
X2 is offline
Old 10-10-2004, 08:12 AM
jag88's Avatar
I adjust the drop back to give me about 130 deg. Anything over 145 IMO is too hot. To get the most out of your charge you should run the car as soon as possible. If you haven't run in 10 minutes start thinking about a repeak.
My 2 cents.
jag88 is offline
Old 10-10-2004, 02:04 PM
N4S
N4S's Avatar
A battery is fully charged at a temp of around 125*F . If you watch your charger and use a temp gun they will usually start to drop in voltage at that temp. This is before the peak detect shuts it off. Ajg.......Watch your charge , you will see it peak and drop........
N4S is offline
