cyclone tc loose & bumpy setup help >
Old 06-02-2011, 08:56 PM
Questions?? cyclone tc loose & bumpy setup help
hey, i have a cyclone tc that is doing nothing but being super loose no matter what i do. it seams like ill get it close tothe right setup then the next week i race it and its loose again. its loose on power out and in cornering. but then ill get to high speed in the straight and go to turn into the first corner and it pushs. the track is a parking lot but is well preped every weekend and sprayed with soda before racing. im in drastic need of some help. thank you!
XXX-SDRIFTER is offline
Old 06-03-2011, 02:54 AM
Trader Rating: 20 (100%+)
post your class, setup, and tires using.
goots is offline
Old 06-04-2011, 12:03 PM
front:
1.5 deg caster block
1 toe out
-2 deg camber
1.6 stabalizer bar with 2mm spacer
1mm spacer on camber linkage in 2 position
spool
4 deg hub carriers
1.5mm under caster block front and rear
2mm in front and .8mm in back for arm position
and i have a .5 shim in the rear position of the hub carrier to take out the play where it attatches to the arm
blue assosiated springs
40wt oil
in 5th position on tower
and on arms the shocks at 3 hole
droop n/a
ride hieght 6mm
rear:
3 deg cater block no spacers under them forward or back
-2 deg camber
camber link in 2 hole with 3mm spacer andin the inner hole for axle carrier
no sway bar
green springs associated
40wt
hole 2 on tower and 5 on arm
arm postion at 2mm front .7 rear
hub positon at 2mm rear and .7 front
droop n/a
ride height 5mm
thank you please help
Old 06-04-2011, 01:26 PM
Where you have "n/a" for droop, does that mean you are not running any? If not you need some. I used to run about 4 or 5mm droop on our unprepared medium grip asphalt track
JR007 is offline
Old 06-04-2011, 04:03 PM
no i messure from the top of the axle usually to get it exact i just dont know the messurment from the center of the arm. im guessing its around 8 to 8.5. but what about the restof the setup? im lost. im to aggressiv for this setup
Old 06-04-2011, 07:14 PM
I don't know the Tamiya springs, so i'm not sure how hard they are. One thing you must remember is that you want the car to maintain a level of balance front and rear. For example, a 1.6 front sway bar, but none in the back may create excessive roll in the back, so maybe add a 1.3 rear sway bar.
Also, having the same oil front and rear, but different springs, will create a different damping effect. If you have a stiffer front spring, have thicker oil to go with it.
One other thing to do if all else fails, go back to the factory set-up. It's not bad for many tracks.
JR007 is offline
Old 06-06-2011, 04:28 AM
is your car balanced left to right? stock setup is a good starting all-around tracks. I run on prepped asphalt track. And I made a few changes. everything else stock
front
5.5mm ride height
1.5 camber
2.0 toe block
1 degree toe out
1.5 under toe blocks and camber link
3 hole piston
37.5 AE oil
pro4 gold springs
#3 on shock tower
1.2 sway bar
droop 4mm over ride height
rear
6.0mm ride height
1.5 camber
3.0 toe block
3 hole piston
37.5 AE oil
pro4 silver springs
#4 on shock tower
1.2 sway bar
droop 3.5mm over ride height
goots is offline
