Old 10-03-2004, 06:18 PM   #1
Default com lat
i just bought a twister com lat. does any one know the right height for the diamond bit. the way that it was set up when i bought it had two gold washers and a thin plastic piece under the bit and when i try to cut the com it hacks up the com so if any one could help me that would be great thanks
duanef is offline   Reply With Quote
Old 10-03-2004, 08:00 PM   #2
do you mean a comm lathe?
Tony Szep is offline   Reply With Quote
Old 10-03-2004, 08:31 PM   #3
yes
Old 10-03-2004, 08:55 PM   #4
fatdoggy's Avatar
R/C Tech Charter Subscriber
Sounds like your bit is either too high or too low. You want the bit to contact the comm at it's center or just a touch higher. You space the bit higher or lower with shims. If you didnt recieve any just use thin sheets of metal. It normally takes a little while to get it right.
fatdoggy is offline   Reply With Quote
Old 10-03-2004, 10:05 PM   #5
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Sounds like that bit is toast too.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
