Old 10-03-2004, 02:00 PM   #1
Send a message via AIM to dasupacat
Default Novak or Rayspeed discharger...?
I need a dishcarger...I know all about the Novak, but don't know much about the Rayspeed discharger. Except that it's cheaper. Can anybody fill me in on which they prefer and some specs on it? does it discharge to .9v per cell? Do I have to moniter it? etc.
dasupacat is offline   Reply With Quote
Old 10-03-2004, 03:19 PM   #2
Fire's Avatar
the novak is pretty much the same as the rayspeed, except on the novak you can adjust the cut off voltage and on the rayspeed you can adjust the dsicharge rate
Fire is offline   Reply With Quote
Old 10-03-2004, 04:25 PM   #3
What amps can you discharge on Rayspeed?
Old 10-03-2004, 06:14 PM   #4
i like the novak. i never use it as a discharger, i use a indi reator 30, and then the novak to equalize. this set up produces amazing results.
e money is offline   Reply With Quote
Old 10-03-2004, 07:10 PM   #5
The major difference between the two is that you can place a fully charged pack on the Novak. The Rayspeed does NOT recommend doing this. However, I have taken a pack after a run and placed on the unit without any problems.
The Rayspeed has two modes. An equalizing mode and a conditioning mode.
The Equalizing mode discharges at 5A down to 0.9v
The Conditioning mode discharges at 1A down to 0.1v
There is NiMH and NiCD switch with a fixed 0.9v or 0.01v shutoff respectively on the battery type.
The unit comes with a nice fan and works as designed. I have been using the Rayspeed for three months without any problems. The Rayspeed unit uses thumb screws to make contact with the batteries the Novak unit uses tabs. Some people have complained that the screwed had worn out quickly, I put a tiny bit of dielectric lub on the screws and have not seen a problem.
The Novak is pain with certain pack configurations.
I race with others who have the Novak and we have swapped units a few times and I cannot say that either of us have seen a major difference between the two in terms of battery performance. They both do the same thing in that sense and they help keep the batteries matched.
The Novak units benefit is the adjustability -- it all depends how much more important that feature is to you to justify the extra cost.
I own two Rayspeeds and I have used the Novak for several weeks at a time and I would say they are both very good units its a matter of what features are important to you and how much you want to pay for them.
LeadFoot is offline   Reply With Quote
Old 10-03-2004, 08:21 PM   #6
Cool. I think I might try that Rayspeed. Better bargain for me. I like that ut can discharge at 5A to .9v. I won't have to moniter will I?
Old 10-03-2004, 09:38 PM   #7
dasupacat:
No, you will NOT have to monitor it. It also make a big "click" sound when it turns off and if you are close enough and its not too loud in your race pit you will hear it. Also, each cell has a light and as each cell hits the cut off you will see its light go off.
Old 10-03-2004, 10:08 PM   #8
donoman's Avatar
Send a message via Yahoo to donoman
The best advice is to use the Search function.
donoman is offline   Reply With Quote
Old 10-06-2004, 06:59 PM   #9
Will the Rayspeed discharge a 4 cell pack?
Old 10-06-2004, 07:14 PM   #10
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Yes it will dischare a 4 cell pack. Just make sure the battery bar placement is correct which is self explanatory.
EA Motorsports
picco007 is offline   Reply With Quote
Old 10-06-2004, 07:27 PM   #11
srry bout the dumb ???'s ....so even though it doesn't have contacts for each individual cell like the novak.....it will discharge 4 & 6 cells
Old 10-06-2004, 07:32 PM   #12
Registered User
ritchie's Avatar
yes
ritchie is offline   Reply With Quote
Old 10-06-2004, 07:37 PM   #13
dasupacat:
The Rayspeed Manual is online at the link below. Look under manuals
http://www.yokomousa.com/index3.htm
Old 10-06-2004, 08:36 PM   #14
Fire's Avatar
the contacts for the 2 cells that don't have individual screws are done thru the battary bars on your packs, so each cell are independent of each others when discharging. just 4 less screws to mess with
Old 10-06-2004, 10:36 PM   #15
picco007's Avatar
don't worry, there are no dumb questions here.
EA Motorsports
rayspeed discharger emulberry Electric On-Road 2 09-30-2007 10:48 PM
RAYSPEED DISCHARGER TOEBSTER2 R/C Items: For Sale/Trade 7 05-01-2007 02:43 PM
Rayspeed discharger II Fast R/C Items: For Sale/Trade 10 02-20-2007 11:09 AM
FS rayspeed discharger rai13 R/C Items: For Sale/Trade 1 12-14-2005 01:21 PM
Rayspeed discharger P2 R/C Items: For Sale/Trade 4 03-19-2005 08:40 PM
