Ko Vantage Esprit II Type R probs? >
Old 10-03-2004, 10:42 AM
Sleighty's Avatar
Default Ko Vantage Esprit II Type R probs?
hey,
Just bout this radio but cant work out how to change the system level on it, so that i can adjust more.
read the manual but cant quite understand how to do it
any suggestions
cheers
Sleighty is offline
Old 10-03-2004, 02:18 PM
Fire's Avatar
talk to some local racers who uses KO EX 1, i think they work about the same
Fire is offline
Old 10-03-2004, 02:21 PM
You need to get it into System mode. Can't remember, but i think you have to press up and down at the same time as you turn it on. There is then the system level option that you can alter.
MattW is offline
Old 10-04-2004, 11:45 AM
Sleighty's Avatar
thanks 'mattw' i'll give it a try
Sleighty is offline
Old 10-04-2004, 11:48 AM
John_S's Avatar
what i do is when the radios on pres the up and down buttons then press select then u can scroll through the system menu and change stuff note u need to change ur system level and then press direct twice for it to activate
John_S is offline
Old 10-04-2004, 01:45 PM
Are the Vantage Type R and Mars R modules the same? Kinda thinking about trying out a dual stick radio and want to be able to run it on 75mHz.
NismoSkyline17 is offline
Old 10-04-2004, 03:05 PM
No, modules are different.
John, yes that is the other way of getting into system mode.
MattW is offline
