Old 05-13-2002, 07:27 AM   #1
Regional Moderator
Addict sa RC's Avatar
Default How to tell when diamond bit is chipped?
How can you tell when a diamond bit is chipped? What would be the symptoms on the comm being cut?
Addict sa RC is offline   Reply With Quote
Old 05-13-2002, 08:16 AM   #2
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: How to tell when diamond bit is chipped?
When my Hudy bit chipped (my fault...I wasn't paying attention and dug it into the windings tab!!), the metal being cutoff did not come off in tiny 'bits' instead I got a 'flake' of comm comming off. Looked a bit like a sweet wrapper!!
To check, just use a magnifying glass and look on the 'shiny' side of the tip....it will be obvious if it is chipped because the edge will not be smooth!!
dtm is offline   Reply With Quote
Old 05-13-2002, 08:23 AM   #3
Regional Moderator
Darkseid's Avatar
Well the tears running down your face as you realize what you have done to that extremely expensive bit, could be a symtom!
TLR 22...Tamiya F104...
Old 05-13-2002, 08:31 AM   #4
dtm
dtm's Avatar
haha...thats one way of putting it......I screwed up mine in a real stupid way. Was cutting a few comms. Set the stops on the first comm, finished. Put the second comm in.....was watching TV forgot to set the stops.... watching TV and then OUCH!!!!!!! bye bye cutter!!!!!!!
I now NEVER watch TV when cutting comms!!!!
Old 05-13-2002, 10:27 AM   #5
Regional Moderator
dtm, thanks. I'll be checking it tonight to see. Much like what happened to you my attention wasn't fully on the task when all of a sudden the arm stopped dead in its tracks because the bit caught on the windings tab
Darkdeid, hehehe.
Old 05-13-2002, 11:03 AM   #6
Peter Busch's Avatar
R/C Tech Charter Subscriber
You can send them in to cobra and they will fix it if possible for $25.00.
Been there done that.
Peter Busch is offline   Reply With Quote
Old 05-13-2002, 11:06 AM   #7
Regional Moderator
Darkseid's Avatar
Its good to know that theres a possible option other than replacing it. I hope you can get yours fixed.
Old 05-14-2002, 01:10 AM   #8
Regional Moderator
Ok. I checked the bit with a magnifying glass and there is no visible indication that it's chipped. The cutting edge is still smooth and sharp . Whew. I guess I'm a little lucky.
Old 05-14-2002, 03:40 AM   #9
dtm
dtm's Avatar
You are indeed lucky!!!
Old 05-14-2002, 11:46 PM   #10
Trader Rating: 69 (100%+)
addict sa RC: do you know where i can get diamond bits, other than the lhs? right now im using carbide bits that i buy from a hardware store. theyre very inexpensive. thanks for any info
marvi is offline   Reply With Quote
Old 05-15-2002, 05:45 AM   #11
Regional Moderator
marvi, I think the lhs has a diamond bit but it's for the Trinity Tru Lathe. Bring your lathe and ask Mang if that bit would fit your lathe. As for me, I have the Xipp Super Lathe and I bought the diamond bit right off the bat from Integy.
Old 05-15-2002, 06:33 PM   #12
thanks i have a cobra lathe that came with a carbide bit. had i known that they have one that comes with a diamond bit for a few $$ more, i wouldve bought that
Old 05-15-2002, 08:29 PM   #13
newracer's Avatar
Default other source of bits
you can get diamond bits from
http://www.mcmaster.com/
for pretty cheap
newracer is offline   Reply With Quote
wtb diamond bit crashnsmash R/C Items: Wanted to Buy 2 10-12-2007 09:46 PM
For Sale - Chipped Xbox! + LOADS MORE. Mloclamau Australia For Sale/Trade 11 06-05-2007 02:54 AM
diamond bit dakrat R/C Items: Wanted to Buy 5 06-04-2005 09:35 PM
Shaft gearing chipped and worn teeth dct147 Nitro On-Road 10 04-05-2005 10:34 AM
sharpening chipped Diamond lathe bits Super Steve Electric On-Road 10 05-30-2004 11:00 PM
