How do I make a spool? >
Old 10-02-2004, 07:05 PM
ChadCapece's Avatar
I'm going to run mod on a tight track, so I need a spool for the Pro 4. No company has begun to distribute a spool for the Pro 4. Can someone describe to me the process for making a spool out of a standard Pro 4 diff? And advice or links would be greatly appreciated. Thanks Chad
ChadCapece is offline
Old 10-02-2004, 07:08 PM
pink pac man's Avatar
just fill the diff with supa glue and try to take as mutch of the parts out.................rotating waight oh and buy another diff
pink pac man is offline
Old 10-02-2004, 07:26 PM
I wouldn't recommend CA glue, it makes your parts useless afterwards. Here's a pretty good way to "convert" your ball diff to a spool.
1. Remove the diff balls and diff rings.
2. Replace the diff rings with a piece of header card that is cut to the same size (that thin cardboard that the name/price/etc. of a part is printed on)
3. Screw the diff back down really tight.
(Note: there may be another/better way to build this.)
This way, the diff acts like a spool, but if forced, it will give a little, so you don't snap parts. Hope this helps.
micros_rock is offline
Old 10-02-2004, 07:27 PM
ChadCapece's Avatar
Thanks for your advice. Is there a way to bolt a diff shut? I've heard of this, but never been told how to do it?
Old 10-02-2004, 07:33 PM
EDWARD2003's Avatar
Default Spool out already
check out www.teamorion.com they just posted a pro 4 spool that hpi came out with.
Edward
EDWARD2003 is offline
Old 10-02-2004, 07:34 PM
Nrctc3's Avatar
HPI just released the spool for the Pro4.
Nrctc3 is offline
Old 10-02-2004, 07:39 PM
whats the point of a diff anyway....... what does it do?
big_dave is offline
Old 10-02-2004, 07:42 PM
Nrctc3's Avatar
The diff allows the outside tire to rotate faster than the inside tire to help it turn. The spool locks both tires.
Nrctc3 is offline
Old 10-02-2004, 07:44 PM
cos when you turn a corner the outer wheel has to travel a larger curcumfrence than the inner wheel so the diff alowes the wheels to spin at different speeds when cornering......................................do you get it
Old 10-02-2004, 07:45 PM
could insuffcient grease on my diff be causing me to spin around corners........esp when im comnig out of apex........all i hear is a loud squeel and then im turned around lol. Yea i get it 100% ive jsut never really thought of it
big_dave is offline
Old 10-02-2004, 07:46 PM
and a spool is a completly solid shaft with no diff action at all
Old 10-02-2004, 07:48 PM
man you guys post quik......................i pack the crap out of my diffs so i dont have to rebuild them all the time but it could be that your diff is to loose
Old 10-02-2004, 07:53 PM
Default spool
go to hpi website they are getting ready to realease a spool for the pro 4
literw2 is offline
Old 10-02-2004, 07:57 PM
is alread out look up the page or go to www.teamorion.com
Old 10-02-2004, 08:04 PM
LosiRacerX's Avatar
so would you put the diff in the front or the back for a tc3
LosiRacerX is offline
