please help 12th scale setup station inside >
Old 05-28-2011, 02:16 AM
Phazewun's Avatar
Trader Rating: 40 (100%+)
Default please help 12th scale setup station inside
Was wondering what people are doing to setup both their 10th scale TC and the 1/12 pans..
i know integy makes a kit but its not due now till late june =/... is there adapters or something you can buy to make it work ??
sorry just new to the 12th scale game.
Phazewun is offline
Old 05-28-2011, 08:34 AM
Default set up station 1/12th
Dont waste your money buying a set up station not needed, all the settings for a 1/12th can be done on the work bench with a nice flat surface, a ride height gauge and camber gauge cost washers.Not lots you can do with a modern link 1/12th car.
tellan is offline
Old 05-28-2011, 09:35 AM
Phazewun's Avatar
thank you thats just what i was looking for.. time to pull out that old rpm camber guage.
Phazewun is offline
Old 05-29-2011, 09:33 AM
Phazewun's Avatar
anyone know what integy adapters work for 12 pan ?
Phazewun is offline
Old 05-29-2011, 11:55 AM
As said above but I would include balance points and tweak station (quarters and an xacto will work too).
AreCee is offline
Old 05-29-2011, 12:53 PM
There are ways to do setup without a station so as was mentioned it isn't necessary...but a station makes things sooooo much easier. I have a tendency to bang up my rims and have them warp so I don't like to use a camber gauge on the rim. Personally I use the Hudy setup station made for pan cars...very nice station but a bit pricey. I don't know of any that work on both pan car and TC.
InspGadgt is offline
Old 05-29-2011, 09:14 PM
Using a hudy setup station now. But to be hornest, spending 100 dollar on a setup station for just camber and toe... I don't think it is necessary..... I only get it that day because I had a really bad day and just wants to buy something to make me happy. lol Just tweak station, and the normal stuff like ride height guage, camber guage is all you need for the 1/12.
http://www.hudy.net/xhudy/products/p...2&kategoria=64
gpm-parts.com is offline
Old 05-29-2011, 10:16 PM
Phazewun's Avatar
how do you guys adjust toe with no setup ?
Phazewun is offline
Old 05-29-2011, 10:20 PM
Still Bill's Avatar
Trader Rating: 16 (100%+)
Same here...I have a Hudy pan car setup station; but, have never used it.
A setup board (with lines) and camber gauge handles everything.
Don't even use quarters on the front end anymore...Spin both front wheels and slowly lower the front of the chassis using an X-acto knife blade in the center. Adjust rear tweek screws until I get both fronts to touch down at the same time. Yes, I use some preload on the rear springs for all situations.
Bill
Still Bill is offline
Old 05-29-2011, 10:21 PM
Still Bill's Avatar
Just align to the lines on a setup board...simple!
Hudy decal on any setup board is great.
Old 05-30-2011, 01:20 AM
I don't even use the sticker side of my Hudy board...I find the sticker isn't very flat so it messes up my camber adjustments. I'll stick with my Hudy station
Old 05-30-2011, 08:28 PM
Still Bill's Avatar
Bert,
You have too much heat and humidity in Hawaii for stickers to keep stuck amigo.
I hear you about them coming unstuck from the board. I replace mine about every other year.
Bill
Old 05-31-2011, 03:19 AM
BrodieMan's Avatar
If you are still after a TC, 1/12 station.
http://www.integy.com/st_prod.html?p...29&p_catid=163
I'm cancelling my backordered setup station and continuing using camber gauges and setup board and saving some money
BrodieMan is offline
Old 05-31-2011, 08:29 PM
Still Bill's Avatar
Spend the dough on something that makes you go faster...Simple can be mo better...LOL
Bill
Old 05-31-2011, 09:19 PM
Originally Posted by Still Bill View Post
Bert,
Bill
Oh it is still stuck...it's just I can feel the plastic taper a bit about 1/2" from the edges. Pretty much been like that since day 1 for me.
