foam tire Q's
Old 10-02-2004, 09:20 AM
dado11g's Avatar
Default foam tire Q's
what tires should i use in my ft tc3 on carpet tracks? im talking about foam and the compound and makers and width. thanks ( also what should i use on asphalt?)
dado11g is offline
Old 10-02-2004, 09:22 AM
Korey Harbke's Avatar
Try Jaco 28mm Purple/orange up fronts and JAco 28mm Purples in the back to start
Korey Harbke is offline
Old 10-02-2004, 09:24 AM
dado11g's Avatar
i will also mention that i am running a 9x1 motor in it. and i will also run a monster stock too.
dado11g is offline
Old 10-02-2004, 09:25 AM
Oh and also try Jaco 28mm double pink/orange up front and jaco 28mm double pink in the rear. Both combo's work good on carpet.
-Korey
Old 10-02-2004, 04:58 PM
Chill Will's Avatar
On asphalt I would use Purples front and rear (40 shore).
Chill Will is offline
Old 10-02-2004, 05:01 PM
JDXray's Avatar
Try some Jaco DBL PINK/ORANGE and then Jaco DBL PINK you will get lots of grip for that 9t motor.
JDXray is offline
Old 10-02-2004, 06:57 PM
pink pac man's Avatar
Default carpet
try elegi 40 shore all round or 40 up front and 37 at the rear for stock
pink pac man is offline
Old 10-03-2004, 02:54 AM
unless ellegi has changed, they are exotic foams which are designed for asphalt, mainly nitro touring. I found that they don't provide as much traction as jaco's or trc's(also a grp product).
BlackFlagRacing is offline
Old 10-03-2004, 03:01 AM
our lhs stocks up on them and there the best for carpet........................we recently helt the act state titles and like 65% of the best drivers in aus tered up all were using ellegi [very populer in australia]
