Old 10-02-2004, 09:19 PM   #16
SlobbaTech's Avatar
The only difference in endbells from yok, top, or epic based to where you'd need a different endbell is for the big comm motors. The brush hoods on the V2 endbell are super close to the comm, so if you pyt v2 endbell for a small comm motor on big comm motor the hoods will more than likely hit the comm if it fits on at all. Other than that I don't see any other difference between brands. On "normal" endbell mod motors you can put any endbell on any motor, just have to switch hoods out to stick with the stand up or laydown setup you're replacing.
SlobbaTech is offline   Reply With Quote
Old 10-02-2004, 10:46 PM   #17
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
The V2 endbell you bought is for stock motors. That's why it has bushings, not bearings. And I don't think the endbell will even go onto the Reedy Quad because of the big comm. It won't physicaly fit I don't think because of the brush hoods. And the reson for soldering directly to the brush hoods is for maximum power to get to the brushes. The original protypes for the V2 endbells didn't even have soldered power wires. They were held into a hold with a set screw if I remember right.
Jon Kerr is offline   Reply With Quote
Old 10-03-2004, 01:47 AM   #18
pink pac man's Avatar
it says that the v2 endbell fits on stock and 19t motors but i bought it for my stock motors ................i was just wandering if it will fit on the reedy [which it doesnt]
pink pac man is offline   Reply With Quote
Old 10-03-2004, 03:46 AM   #19
Send a message via AIM to BlackFlagRacing
I believe it was ment for 19 turn spec motors with locked timing and bushings. I know that on my v2 the end bell bearing is only held in with an o-ring.
BlackFlagRacing is offline   Reply With Quote
Old 10-03-2004, 07:39 AM   #20
is there a difference in performance/looks etc between the peak vantage endbell and the orion v2 endbell
Old 10-03-2004, 07:54 AM   #21
Hi,
Those are exactly the same!
Thomas
840918001 is offline   Reply With Quote
Old 10-03-2004, 08:01 AM   #22
oh ok thats good then cos i try to stay tru to bying peak motors but i didnt know that peak had a endbell adaptor so i got the orion 1 but if there the same then its ok
Old 10-03-2004, 07:13 PM   #23
Super Moderator
Grizzbob's Avatar
Well, Peak& Orion are all basically the same company nowadays(much like Epic & Trinity being one & the same), so I wouldn't worry about it.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-05-2004, 11:34 PM   #24
just got my v2 adaptor and won my stock race with it it goes so hard
WANT VRC USB ADAPTOR signal21 R/C Items: Wanted to Buy 1 03-22-2006 06:52 AM
WTB VRC usb adaptor deoding R/C Items: Wanted to Buy 0 03-12-2006 09:53 PM
WTB: VRC-2 USB Adaptor Exe R/C Items: Wanted to Buy 0 01-26-2006 06:39 AM
[WTB] VRC USB Adaptor thunderbt3 R/C Items: Wanted to Buy 0 01-09-2006 09:02 AM
F-S VRC USB Adaptor rctoyguy R/C Items: For Sale/Trade 5 03-16-2005 08:50 AM
