soldering?
Old 10-01-2004, 01:38 PM
Default soldering?
what solder and soldering flux should i get to make clean connections?
SPC Racer is offline
Old 10-01-2004, 01:50 PM
Suspended
get the one from Deans...it has flux inside the solder
403forbidden is offline
Old 10-01-2004, 02:06 PM
deans is the best it has a high silver content so you get barely and resistance
kh15 is offline
Old 10-01-2004, 06:19 PM
yeah deans is good stuff a little pricer than other solders but worth it, like 3.50 a tube.
Javen13 is offline
Old 10-01-2004, 07:08 PM
Charlie O's Avatar
If you can't get deans easily, try (Kester) 60/40 it flows really well and is super strong, as good as deans or better, try hardware or electronic stores, dont use radio shack solder!
Charlie O is offline
Old 10-01-2004, 08:21 PM
Not to nitpick but....Thats the first time Iv'e heard someone say not to use radio shack solder.......can I ask why?
Joe B is offline
Old 10-01-2004, 08:41 PM
DOMOisCOOL's Avatar
I've been using Radio Shack 60/40 solder with awesome results. And a whole roll is cheaper than the Deans solder IMO.
DOMOisCOOL is offline
Old 10-01-2004, 09:08 PM
Same here
Joe B is offline
Old 10-02-2004, 05:30 AM
Default 60/40 w/ rosin core
Can't get easier than good old 60tin/40lead rosin flux core solder. No separate flux required. I bought a 1lb roll of ultra fine stuff 10 years ago and use it for everything from soldering fine circuit board components to RC cars. Get yourself a decent iron that will has replaceable tips. It will last a lifetime. The Weller WLC100 is a good value. It has variable heat and a slew of available tips. Get one thick blade and one fine point tip.
Weller WLC100
Disaster is offline
Old 10-02-2004, 08:36 AM
Nrctc3's Avatar
Where can I get some flux?
Nrctc3 is offline
Old 10-02-2004, 08:38 AM
S.Stew's Avatar
deans.
S.Stew is offline
Old 10-02-2004, 11:48 AM
Charlie O's Avatar
Just that the Kester or Deans is alot better, i have had the radio shack solder Archer 60/40, & it just wouldn't flow onto some wires & other various items to be soldered, even just trying to tin them, where as the Kester & Deans tinned up & flowed really well on the same items, try some you will like it much better.
Old 10-02-2004, 02:16 PM
onebeatuptc3's Avatar
If you cant get it to tin to easy use flux. Everytime that happens, i put some flux on the wire and the wire will tin. Ive never had a problem with radioshack solder either, it mostly flows perfect for me. Maybe you just keep getting bad rolls of solder, because that can happen. If you do stained glass you would understand, you can get a whole case of bad solder (its a little different then electronic solder tho)
onebeatuptc3 is offline
Old 10-02-2004, 04:46 PM
Lost Aggresiva's Avatar
It's always good to have some extra flux on hand. It helps get rid of surface corrosion that stops the solder from flowing properly. Just don't use too much because leftover flux on the connection will attract moisture. Air + Moisture + the ends of your batteries and things can get ugly after a while.
Just my $0.02.
Lost Aggresiva is offline
