Tamiya TT-01 Gearing Question
Looking at the table below, what size pinion should I get?
I have a 55 and 58 tooth spur, running a tamiya sports tuned brushed motor and mainly drift wheels. http://forums.radiocontrolzone.com/a...6&d=1258554012 I can't find any good info on the internet. |
Larger pinion/smaller spur gives more top end/less acceleration/higher motor temperatures.
The sport tuned motor can probably pull a ratio around 6:1 quite easily. Aside from that, just gear to suit your needs. |
If drifting with the sport tuned you can go with a 24/58. Remember to run a heat sink and even a fan on the motor.
To Damo_MadTruck
Awesome job posting the chart.
That's what I do at the LHS as well haha. Picture says thousands words. |
