Old 05-17-2011, 08:28 AM   #1
Default team associated tc5 gearing?
I have a team associated tc5 and I am running in the vta class with at novak 25.5 ss motor with the havoc 2s esc right now it has a 87 spur gear on it if you can help me with the gearing it will be helpful thank you in advance?
blitz15 is offline   Reply With Quote
Old 11-06-2011, 05:30 PM   #2
Lethal Enforcer's Avatar
Trader Rating: 97 (100%+)
bump
Axial Scorpion ,Team Associated TC5R , Tamiya M03R, Tamiya RC Onroad.com
2012 TCS Best of show Mini
2012 TCS Best of show TT01
Lethal Enforcer is offline   Reply With Quote
Old 11-06-2011, 06:18 PM   #3
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Get yourself a smaller spur like a 72 and get some 37-40 pinions. That should get you in the ballpark, I think I switched over to 64 pitch gears when I was gearing mine with a 21.5. The problem you may run in to is getting the gears to fit/mesh. Ask around at the track what FDR people are shooting for..
Check out these sights..
http://www.gearchart.com
http://www.precisionracingsystems.com/
http://www.robinsonracing.com/
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\MIP\JConcepts\Schelle\ProlevelRC
Logi Maker is offline   Reply With Quote
Old 11-06-2011, 06:29 PM   #4
Rysuleod's Avatar
I run a TC5R in VTA on a 98x60 carpet medium traction. I use a 100 spur and 50 pinion for an overall 4.0 FDR. TC5 internal ratio is 2.0.
I drop down to a 47 pinion if the layout is a little tighter 4.26 FDR.
Rysuleod is offline   Reply With Quote
Old 11-06-2011, 06:36 PM   #5
hnasdad's Avatar
Here is a gear chart that someone did a great job on, not mine. But this is for the tc6, I would guess this will get you close to what will fit. That is the problem, Not sure about your FDR for that motor. Hope this helps
http://abram.eu.org/gear_tc6.php
If you wreck in the same spot twice, your going too fast.
Tell a man his pinion he races today, teach a man about final drive ratio and he will stop making posts about them on forum's
Sketchy Racing (SC10,B44,10L5 Oval,TC6)
hnasdad is offline   Reply With Quote
Old 11-06-2011, 06:50 PM   #6
Old 11-07-2011, 03:18 AM   #7
In VTA are you not limited on the fdr you can use? I thought I heard 4 was max somewhere.
The 80t spur from TC6 should fit the TC5 I guess, did not try it, otherwise they are some spurs out there that will fit but watch out for the XRay's spurs, the holes are not the same, I know i got some
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-08-2011, 12:56 PM   #8
I am going to try a 72 spur and a 37t pinion
Team Associated TC4 Kenshin Electric On-Road 15355 Today 09:23 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
