Old 09-27-2004, 04:00 PM   #1
Default how to remove magnents
how can i take the magnets out of the can to fully get all the little iron particles off them?
do the magnents have to go back on in the same spot they came out of?
kh15 is offline   Reply With Quote
Old 09-27-2004, 04:09 PM   #2
Speedie's Avatar
There is no reason to remove the magnets and It would ruin the motor. Just spray out well with motor spray and blast it clean with compressed air.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 09-27-2004, 04:55 PM   #3
i did that about 10 times and the stupid little particles will not come off!
Old 09-27-2004, 05:02 PM   #4
Try using a soft rag to wipe off the particals. If you want o remove the magnets for other reasones, then put it in your oven and heat it to 325 or 350 degrees and they should come out. Remember the motor will be HOT!!
gezer2u is offline   Reply With Quote
Old 09-27-2004, 05:18 PM   #5
wagonman72's Avatar
Gezer what up dawg !!!! tell Josh I said HI.
wagonman72 is offline   Reply With Quote
Old 09-27-2004, 05:52 PM   #6
EddieO's Avatar
R/C Tech Charter Subscriber
You also use an air hose or even high pressure water to blow them off.....just make sure you dry the can well before you reassemble it.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 09-27-2004, 06:44 PM   #7
DUDE! whatz up? how's the move and the new job?
can you remove a piston with out remove the sleeve? downunder23 Rookie Zone 3 08-17-2006 07:00 PM
remove lj_rcgear R/C Items: For Sale/Trade 0 07-16-2005 03:02 AM
Please Remove tg413 R/C Items: For Sale/Trade 4 05-29-2005 09:20 PM
Remove CA? Aku-Man Electric On-Road 11 05-10-2003 08:50 PM
