Which Reedy
Old 09-26-2004, 12:49 PM
Matt Pocknell's Avatar
Which Reedy
After racing stock and 19, I will be racing modified for the first time at a junior championship. What are the differences between the reedy motors (ti, kr, pt), and which one is the best to buy at the moment. I see that the kr seems to be the most popular, but I have heard that it needs tuning and regular rebuilds to keep it up to pace.
Thanks in advance
Matt Pocknell is offline
Old 09-26-2004, 01:26 PM
onnetz's Avatar
I think the pt is more for 1/12 racing, lots of rpm's but not much torque..
and what mod doesnt need tuning and frequent rebuilds?
onnetz is offline
Moderator
Speedo's Avatar
I would recommend the Ti. It is a fast motor, but on top of that it is very easy to set up and always runs well, whereas the Kr can be finicky. Just use Reedy Quasar brushes in the Ti, and keep the comm trued and you'll be in good shape.
Josh
Speedo is offline
Old 09-27-2004, 09:26 AM
Are the ti's still up to performance with the newer type of v enbell motors?
Old 09-27-2004, 01:28 PM
raving-monkey's Avatar
hi, racing at don vallery then?
i will be using a steenari V2 (!2x1) basically because i can't afford a new one
but i have been told that these spashet V2s are going to be loony..i mean real quick and i think they are legal now...
raving-monkey is offline
Old 09-27-2004, 02:42 PM
Sleighty's Avatar
At last years Juniors at Don Valley i ran a Team Orion Core 12x1 HS, Try a V2 or a Krypton those seem to run well round there.
Sleighty is offline
Old 09-27-2004, 03:00 PM
Moderator
Speedo's Avatar
The Ti's are right up there in terms of performance. Just a really solid motor.
Josh
Speedo is offline
Old 09-27-2004, 03:13 PM
my core (modified ) is a gerat motor on the tight and twisty tracks, same as my D5..they have bags of punch...
i recomend getting a V2 tbh...loads of people there will be using them...so no problems getting a decent gearing
Old 09-29-2004, 08:17 AM
thanks for the replies, seems i will get a peak v motor now, mabey even a spashett edition if it is leagal
Old 09-29-2004, 09:27 AM
I just looked at the V 12X1 (if thats what your using) motors and i have to choose between HS and HT, which one is best at don valley?
Old 09-29-2004, 12:49 PM
Nrctc3's Avatar
Give one of the Orion V2 motors a try. Those are extremely popular around here.
Nrctc3 is offline
Old 09-29-2004, 04:42 PM
A_Stratus's Avatar
One of my good buddies, has the V2 (8x1) in his XXX4 and I was AMAZED on the comm and brush wear on that motor! I know if I run mod touring this winter, I will be getting a V2 13 or 12 turn. I haven't heard anybody say anything bad about these yet!
A_Stratus is offline
Old 09-29-2004, 04:51 PM
AdrianM's Avatar
All the Reedy factory drivers are running the Ti motor now.
That said, the Peak/Orion V2's are for real. Just as fast as the Ti bit you can get 3 runs before you need to cut the com and 9 runs before you need to replace the brushes (Enduro).
AdrianM is offline
