Old 02-05-2010, 08:43 PM   #13231
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Since my JRXS is now doing VTA duty, I've taken to outfitting it with Type-R stuff. This picture shows two cool upgrades. The first is the JR-Link. We used to make these out of an extra front suspension arm and c-hub. However, the link was so long it left you with no camber gain. The JR-Link from the Type-R kit (LOSA1218 $10) is about 2mm shorter, so thankfully it does provide some camber gain! The other nice part about it is that it's made of EA3 material.
The other neat thing in this picture is the Type-R steering rack (LOSA1548 $8), which has another set of holes further in on the rack. That provides more Ackerman giving a much livelier steering feel. The rack just has to be bolted in upside down (as shown) because the JRXS bell cranks aren't as slim as the Type-R bell cranks which causes the rack to rub if installed right side up. As with the stock rack, be sure to use a microscopic dab of blue threadlock on the bolts to keep the rack from steadily unscrewing itself.
Two easy bolt-ons from the younger brother Type-R that make the car better for less than $20.
If you guys really want to deck out your mid-motor JRXS, grab the Type-R diffs and driveshafts to lower the pin drag by about 8,000%!
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 02-09-2010, 01:18 AM   #13232
bigshow4u's Avatar
cool tip. What other tips do you guys have?
UPDATE: I have ordered all my new gear so it will be here by thursday at the latest. I will post all the photos of the mod's that i did with instructions. Lets hope the batteries i found will fit properly without no further modification needed.
If it's broke, I can fix it
If I can't fix it, It ain't broke
bigshow4u is offline   Reply With Quote
Old 02-18-2010, 03:06 PM   #13233
Trader Rating: 29 (100%+)
*Waiting patiently to see some light from bigshow*
manthree is offline   Reply With Quote
Old 02-18-2010, 03:33 PM   #13234
bigshow4u's Avatar
sorry it took so long guys but i wanted to make sure this worked before i posted anything. well here you go guys. just finished all the mods and i have raced it.
http://www.rctech.net/forum/electric...ml#post7025152
let me know what you think.
Old 03-08-2010, 10:07 AM   #13235
heretic's Avatar
I want to buy a JRXSR, I really want to, but I am held back by the fact that nothing new is coming from losi... I sent them an email about it. Can someone give me a little hope about something new ? ability to fit 5400 lipos ? a new softer top plate ? Having a car that has such potential in their hands and doing nothing to promote it the slightest bit is driving me crazy.
I DONT want to buy a car that I'll have to modify with a dremel out of of the box just to give it the proper flex. Am I alone in this situation ? Man, if I ended up buying one just before they finally release the much needed updates, that would piss me off real bad. Sorry for the half unnecessary post, I just had to let it out.
heretic is online now   Reply With Quote
Old 03-08-2010, 10:23 AM   #13236
jrxs-r's Avatar
Your questions on the JRXS-R can be answered on this thread for it...
http://www.rctech.net/forum/electric...xs-type-r.html
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 03-08-2010, 10:38 AM   #13237
heretic's Avatar
ah , I feel stoopid, I thought there was one thread for both cars. Guess i just have to copy-paste it. Thanks
Old 04-21-2010, 06:37 AM   #13238
mihy's Avatar
anyone else running lipo in these cars and is the type r got the same issue with lipo fitment
mihy is offline   Reply With Quote
Old 04-21-2010, 06:57 AM   #13239
Tim Johnson's Avatar
Look back in the tread a bit. There are mods to be made for LiPo use.
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 04-21-2010, 12:16 PM   #13240
jrxs-r's Avatar
The JRX-S still lives on!
Got the JRX-S out of storage (2 years) and cleaned the dust off it over the weekend... slapped a current set of electronics in (tekin rs w/ SP V3 10.5), balanced it 50-50 front/rear/left/right, taped in an Intellect IP4000 stick pack LiPo and set it up quite similar to the TypeR (but with softer rear springs).
Went racing tonight (rubber/carpet/no additives), and I couldn't believe that the car drives so nice TQ'd and won both Mains. Easy to drive and very consistent (0.33sec to 0.44secs). Makes me want to put my TypeR down and run this for a while!
Cheers,
Zack
Serpent S411
Old 07-15-2010, 01:47 AM   #13241
Trader Rating: 38 (100%+)
if any one wants a jrxs roller i'll sell mine just pm me.its in good condition been sittin on the self collecting dust
Jmfknpizzle is offline   Reply With Quote
Old 09-08-2010, 11:51 AM   #13242
jhwnissan's Avatar
I am looking forward to getting the one I just bought on the track. Got it for a steal! 75 bucks shipped! Cant get a type r for that money. I will be doing some testing as soon as it comes in and throwing in a 17.5 from speed passion. Good times!
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 07-28-2011, 09:33 AM   #13243
Regional Moderator
cptxaggie's Avatar
Should the new Protek fit without mods?
"These "Sport Race" battery packs are built using a hard plastic case that is the same dimensions as a standard NiMH stick pack, which makes them a perfect fit in any chassis that will accept a 6 cell stick pack. "
Specifications:
ROAR Approved!
Type: Lithium Polymer
Capacity: 3800mAh
Voltage: 7.4V nominal
Connector Type: 4mm Pin Style
Balancer Type: Not Included
Number of Cells: 2
Weight: 208g
Configuration: 2S
Dimensions (WxLxH): 47x138x25mm
Maximum Charge Rate: 2C (7.6A)!
Maximum Continuous Discharge: 50C (190A)
Maximum Burst Discharge: 100C (380A) for 3 seconds
cptxaggie is offline   Reply With Quote
Old 07-28-2011, 10:39 AM   #13244
bigshow4u's Avatar
I am willing to guess no. The reason is that the NiMh cells are rounded at the ends which is what the car was built around. Thats what causes most of the fit issues with this chassis. But there is only one true way to find out and that is to buy one and see. I wish i could help further but i am limited to what i can do. You may want to look at the 3300 packs and see what there dimensions are and compare them to this pack. If they are the same then the same mods i did for mine will work for this pack. Really for the length of the race i truly didn't need anything over 3000 mAh. Brushless motors are so efficient that they don't typically need the high mAh (at least for VTA) Buggies and Truggies are a dif story.
I would try it myself but I no longer have this car. It was VERY successful at the track and i got an offer I could not refuse. Hope this may help.
Old 07-28-2011, 08:37 PM   #13245
Blue Screw's Avatar
Send a message via AIM to Blue Screw
I am alsowilling to sell my type R i raced for losi for a little before i got with ae.. thecar has been run maybe 4 or 5 tmes.. has pletny of parts, all the springs, plus special spring that were tested... hmm has the flying fox shaft and spool plus the stuck one, extralcds, cerimic bearings plus the stock new set.., steel batt tray, hard bumper, opoinal toe plates.. ect... like i said car has been raced 4 or 5 time at big races thats it.. pm me for more info..
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
