Old 01-11-2009, 07:20 PM   #13156
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
ive done what you guys have said and my orion 3800 still wont fit
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 01-14-2009, 08:24 AM   #13157
does anybody have any suggestions?
W.P.A.C crawlers
The Raceway
Old 01-14-2009, 01:54 PM   #13158
You might have to dremmel the rear part as well. I used the hard case batteries from rcmarket and the only thing i had to do was cut the to edge off the battery. you should check out the site.
joe_p is offline   Reply With Quote
Old 01-14-2009, 08:45 PM   #13159
i did dremal the rear in the pic i didnt but i just did i little bit ago and it still doesnt fit
W.P.A.C crawlers
The Raceway
Old 01-14-2009, 08:52 PM   #13160
its kind of hard to see where the battery is hangin up. From what i can see in the pic, I would say you have to shave more of the plastic in the back.
Old 01-14-2009, 09:32 PM   #13161
here is some pics of mine. as you can see the center section is still original and the back has been shaved a bit. the back was shaved so it would fit the NIMH six cells. All i did was remove the top piece off the lipo, cut the corners off, glued it back on with shoe goo, filled the corners with shoes goo, and taped them off to hold the goo. The battery fits perfect. These batteries are 136mmx44mmx17mm 3500 25c. the orions are 136mmx47mmx22mm. As you can see there is 5mm difference in height which make a big difference. the lipo make fit without mod since your vehicle has been cut already. here is the link if your interested.http://rcmarket.com.hk/product_info....oducts_id=4617. i am going to buy another lipo so i will post pics of the mod when i get it.
Team Losi JRXS-img_0001.jpg   Team Losi JRXS-img_0003.jpg   Team Losi JRXS-img_0004.jpg   Team Losi JRXS-img_0005.jpg
Old 01-15-2009, 01:25 AM   #13162
If you look at Kcunamay's 3800 install you'll see you need to remove more material from the rear bulks to get the 3800 to fit. With the 3400 you don't need to remove much material from the rear bulks. The 3800 is really a tight squeeze, I've seen his car in person.
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 01-15-2009, 01:29 AM   #13163
Originally Posted by stu541 View Post
My gtb doesn't like the 3.5 fdr with a 17.5 and it thermal shut off at approx. 6.5 mins. Not having my pinions I bought a diff. spur at the track and got it up to 3.85. It was way more responsive and my times showed it as I got them down in the low 11's. For any newbies I would start closer to 4.0 and you'll probably settle in around the 3.8 mark. my .02 worth. If any one wants to try my set up let me know and I will post it.
Thanks for the info. I'm running 3.51 with my Novak 17.5 and it's got good top speed but not that much punch coming out of the corners. I've been thinking of moving in the direction you did. Which gear set did you use? Did you loose much top speed? I noticed you're running on a smaller track so that may not have been an issue.
I've got the 118 spur now.
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 01-15-2009, 02:35 AM   #13164
kcunamay's Avatar
Trader Rating: 20 (100%+)
The 3800 does fit, it just needs a lot more massaging. My pack stays mounted in the vehicle at all times. I could take it out, but have no need to.
Looks like you did all of the dremeling needed aside from a little bit on the sides of the pack to clear the pulley's. You might want to massage a lttle bit off of the the top of the pack (opposite end of the plug side) to clear the motor mount. Uncrew the 4 bolts that hold down the rear bulkhead and the 4 that hold the 4 posts to insert the battery. You want the pack to fit in the chassis and not rub on the pulleys at all. Once the pack is in, you have to do some shaving on the battery tray for it to seal flat.
It's a lot of dremel work, but totally worth the effort once its done. Fit the battery, see where it rubs, dremel and try again. My pack fits in perfectly with no rubbing, stress on any parts, and does not place any tweak on the chassis at all. It is still completely flat.
Good luck!
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 01-15-2009, 07:49 AM   #13165
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
If anyone is looking for parts for the jrxs I have a bunch of new in the package parts that I am looking to get rid of. Click here.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-23-2009, 07:07 AM   #13166
Trader Rating: 25 (100%+)
Can any help with a question.
Is there a kit available to change a JRXS to a JRXS type R?
If not what is needed for the conversion?
fred kellner is offline   Reply With Quote
Old 02-23-2009, 07:13 AM   #13167
Yeti35's Avatar
What is need is you go to your LHS and just buy a Type R kit. There are only a few things interchangeable between the two cars. The layout of the cars is completely different and there are no conversion kits. Chassis's are not the same either.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 02-23-2009, 08:07 AM   #13168
hey i have a losi jrxs with tons of parts and its only been run on carpet 5 times 110 shipped pm me if interested
W.P.A.C crawlers
The Raceway
Old 04-06-2009, 05:25 AM   #13169
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Hi,
Can I see some more pics of the mods needed to fit a Lipo into the JRX-S . Thanks
Sworkz EVOII LE/Hobbywing/Protek
Roche Rapid F1/Hobbywing/LRP
Taffyjnr5 is offline   Reply With Quote
Old 07-17-2009, 09:18 AM   #13170
Taffyjnr5's Avatar
Hi,
Does anyone still run this car.....
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
