Old 10-10-2007, 03:14 PM   #13111
morris's Avatar
Trader Rating: 40 (100%+)
could anyone put me in the right direction to get a good starting set-up for rubber tire on carpet...this is my old car and it had the set-up from the losi site for foam tire on carpet....old friend getting back into rc and im going to lend him the jrxs while i rip the type-r.
was just wondering or should i say asking for set-up help..
i cant find set-up nowhere for the car.
thx,
matt
morris is offline   Reply With Quote
Old 10-10-2007, 04:43 PM   #13112
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Hey Matt, Go back one page (437) and scroll down to Mike Haynes' Snowbird set-up. His cars are always dialed on carpet and I remember him saying that set-up was easy to drive.
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 10-10-2007, 04:50 PM   #13113
morris's Avatar
vdubb-thx i loked at it.i do not have a one-way or 56 pistons for the car.
i think i will just have to make it soft.............lol
Old 10-10-2007, 04:54 PM   #13114
Kwikvdub's Avatar
I've tried that set-up with a diff in the front, on the tight side in stock, and it was BIG Fun!............ Try it, let us know.
Happy Racing!
Alex Valdes
Old 10-27-2007, 05:31 AM   #13115
PhilMart's Avatar
Default Front suspension arms
Hi all
I am wondering if there is an aluminium after market replacement for the front suspension arm for the JRX-S
I have busted four of these in the past month. In some cases its as a result of "seemingly" glancing off the boards. It almost seems that the angle of the hit shatters the whole arm.
Phil
PhilMart
Losi JRX-S | Mamba Max 7700 | Ko Propo Mars Ex-1
PhilMart is offline   Reply With Quote
Old 10-27-2007, 08:30 AM   #13116
Originally Posted by PhilMart View Post
Hi all
Phil
Have you tried the parma bumper on your car? It's quite a bit stiffer then stock and usually helps you avoid breaking arms in an accident.
duckman996 is offline   Reply With Quote
Old 10-27-2007, 01:26 PM   #13117
Yeti35's Avatar
Hi all
Phil
You would not want that for it will just end up breaking other stuff on the car with aluminum arms. Got yourself a Parma or PDub bumper and you should have better luck with not breaking arms.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 10-27-2007, 02:43 PM   #13118
Trader Rating: 27 (100%+)
will this get me in the right direction for foam/carpet
front
-2 degree neg camber, .5 degree toe out
-6 degree caster blks
-42.5 lb springs 40 wt oil shock in the lower hole on the arm (inner) 2nd hole in on shock tower
-camber link in middle hole
-low roll center, low diff
rear
-2 degree neg camber, 2 degree toe in
-20 lb springs 40 wt oil, outer hole on arm 2nd hole out on tower
- camber link is in outer hole on upright and middle outer hole on the tower
1.5 mm front/2 mm rear droop ,arms forward (tight track)
I cant seem to find a good starting set up off the net. I havent tried the above set up yet (I will tomarrow), its where I thought it should be to start out
convikt is offline   Reply With Quote
Old 04-13-2008, 07:07 PM   #13119
Armedforces's Avatar
Thumbs up JRX-S Pro :):)
First of all I have to say after purchasing my JRX-S Pro and running it this Sunday I must say that thing handled like a dream. Now I have couple of questions.
1. What lipo battery will fit JRX-S Pro, I would really like to get away from Nimh.
2. Also I just put a 19T Motor in a car and stupid me I just spooled the motor to test see if it works without breaking at in, did i just messed up the motor buy doing so ?????
Armedforces is offline   Reply With Quote
Old 04-14-2008, 09:26 AM   #13120
Tim Johnson's Avatar
You can fit a Team Orion Carbon battery in to your JRXS.
http://www.teamorion.com/Products/SL...00+2+cell+SLPB
You did not hurt your motor.
Tim Johnson is offline   Reply With Quote
Old 04-14-2008, 06:35 PM   #13121
tom235's Avatar
[QUOTE=Tim Johnson;4353811]You can fit a Team Orion Carbon battery in to your JRXS.
the 3200 will not fit the jrxs it will fit the R but not the s
maxamps has one and so does protec
tom235 is offline   Reply With Quote
Old 04-27-2008, 09:37 PM   #13122
FWR
Is anybody using the JRXS in the the Trans Am class?
http://www.usvintagetransam.com/
And is there a setup that works?
FWR is offline   Reply With Quote
Old 05-02-2008, 08:17 AM   #13123
shadow102's Avatar
Trader Rating: 21 (96%+)
as soon as i get mine i will be swapping everything from my pro3 over so i will let you know what i find out
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 05-03-2008, 04:22 AM   #13124
RevXS's Avatar
I just got two of these,How many parts fit from the R verison of this car? And also is there any other spurs you can get apart from 128t and 118t? Trying to get the right gearing for a stock class but can only just get the correct gearing running the 118t and with a 52t pinion,Hoping to get both cars out on the track in the next month,I think it should handle a dream,car just impresses me more and more every time i read more into it,Anyone else here run them in the Stock class?
RevXS is offline   Reply With Quote
Old 06-14-2008, 08:38 AM   #13125
shadow102's Avatar
[QUOTE=tom235;4355298]
so the orion wont even fit with the JRXS-R lipo battery tray? Got links to the maxamps and protec batts that will fit?
www.nexusracing.com
www.go-rc.org
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
