Old 06-07-2007, 05:39 PM   #13051
thanks again pookyt for the help, and thanks for the compliment.
got another question for you. i know there a way to lift the diff higher on the chassis, my question is when i did this i noticed the belt got tighter, pretty tight actually but there is movement on the belt. is that normal or did i have to do something else so the belt would not tighten up the way it did.
lastly, again newbie jrxs owner here, how do you loosen and tighten the tension on the belts, if you can that is.?
cheech4 is offline   Reply With Quote
Old 06-07-2007, 06:13 PM   #13052
Yeti35's Avatar
You do the belt tension and diff height all with the same method. It is by turning the Diff housing that allows you to do the height as well as belt tension.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 06-07-2007, 08:47 PM   #13053
peded's Avatar
Is there anyway to fit a lipo in the JRXS?
peded is offline   Reply With Quote
Old 06-07-2007, 08:52 PM   #13054
GOOD QUESTION!!! i was going to ask that also, i have the alloy bigger battery tray, and i cant fit my 6 cell shot gun style battery in it so i was waiting on my next check to get me the orion platininum 4800 LIPO. or else im stuck buying more 6 cell packs.
Old 06-07-2007, 09:29 PM   #13055
Yeti35's Avatar
No not w/o distroying the car in the process. If you want a Losi and Lipo, get a Type R. It even comes with a special Lipo tray in the kit.
22 3.0SR
Old 06-07-2007, 09:32 PM   #13056
peded's Avatar
Also what other servo horn will work for JR servo on the JRXS? the ones that comes supplied with the servo are too short and bump into the servo case.
Old 06-07-2007, 09:53 PM   #13057
Yeti35's Avatar
Just get yourself the steering rack assembly from your LHS for it as all the kit servo horns on if for the differnent servos. This is the part number: LOSA1543 .
22 3.0SR
Old 06-07-2007, 10:56 PM   #13058
so even with the larger battery tray that the jrxs comes with, the orion platinum LIPO will not fit?? i seriously hope it does cuz that limits the jrxs to only a 6 cell side by side battery. im just going to have to go to the hobby shop and see if it does.
Old 06-07-2007, 11:44 PM   #13059
tom235's Avatar
no not even! the 3200 is just as bad maxamp has a 4000 lipo that they say will fit but it is not in a hard case and some tracks wont let you run it.
don't go with the 6000 i hear it wont fit but maxamp says it will
tom235 is offline   Reply With Quote
Old 06-08-2007, 12:52 AM   #13060
peded's Avatar
Is there any set up out there for Outdoor Asphalt Foam with slighly rough surface?
Old 06-08-2007, 03:39 AM   #13061
i guess my only option is go to the hobby shop an see what LIPO will fit. or else im stuck running 6 cell side by side packs. Argg ,what a turn off that is, i have a bunch of 6 cell packs just not side by side, i dont want to buy anymore NIMH batteries.
Old 06-08-2007, 06:08 AM   #13062
Send a message via AIM to $rusty$ Send a message via MSN to $rusty$
I haven't seen one, but just run rubber. Those foams are gonna be gone pretty quick on that surface. Just use the Numan set-up that you where talking about earlier.
Rusty Andersen
thercbarn.com
$rusty$ is offline   Reply With Quote
Old 06-08-2007, 06:42 AM   #13063
Yeti35's Avatar
You should have enquired about this before you bought the car in the first place. The larger battery tray was for the 38-4200 NimH cells. This car was never intended to have Lipo fit it. As Tom said you may get a soft cell one to fit but most tracks may want you to have a hard case around it which then you will not get it to fit. It is not a Lipo car so you may want to think about selling it or getting more NimH cells to run in it.
22 3.0SR
Old 06-08-2007, 04:50 PM   #13064
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Hi all,
I have got my jrxs set up pretty well to suit my track, i am just after a little more turn in going into the corners at high speed, what could i change or adjust to achieve this? i lose time going into the corners cause i cant take them as quick as everyone else does. Any help would be great!
Fast XXXS is offline   Reply With Quote
Old 06-10-2007, 01:34 PM   #13065
SORRY, newbie jrxs question coming. where do you tighten the diff screw, is it inside the lcd outdrives like in other cars, i bought it assembled and i didnt take that apart yet.
DTX Evader ST Pro Brushless, Tx Mini E-Revo VXL
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
