Old 04-24-2007, 07:31 AM   #12991
POOKYT's Avatar
Originally Posted by Wasabi
I was wondering if anyone has tried using the new front upper arms from the JRXS Type R on the JRXS Pro? Will it even fit?
Several of us ran the home made version of this link on the JRXS for most of last year. I personally loved it because it keeps thr front end flatter under cornering. Try it -- you may love it!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-24-2007, 07:20 PM   #12992
Capelracer's Avatar
Originally Posted by rinkrat99
Hi all
I ran my JrXs for the first time today on asphalt and was wondering how people are getting a sub 6 FGR with a 118t Spur? Some of these motors need a 5-6 FGR and that would correlate to a 43t pinion.
Or you can go noisy & use the 90t 48pitch spur losi make for it - I can gear down to 5.15 (90/32) before the motor starts to rub on the servo.
Before it starts I use 48p coz I've got a lot of 48p pinions for offroad and couldn't be arsed having to stock up on 64p - also our track has the odd small loose rock and 48p lasts a whole lot longer for me - I watch the 64p guys replace spurs every other run or so
Capelracer is offline   Reply With Quote
Old 04-27-2007, 01:09 PM   #12993
Wasabi's Avatar
429racer - They use the same castor blocks, so I would have to say yes.
Pookyt - Several of us ran the home made version of this link on the JRXS for most of last year. I personally loved it because it keeps thr front end flatter under cornering. Try it -- you may love it!
Thanks Guys I'll order some up. I've heard that the material used for the Type R was kinda weak at the moment, do you think I sould wait a bit?
Wasabi is offline   Reply With Quote
Old 04-28-2007, 02:22 AM   #12994
LOSI123's Avatar
Trader Rating: 63 (100%+)
Does anyone know if LOSA9688 clamp style wheel hex for jrx-s will fit a xxx-s?
thanks....
LOSI123 is offline   Reply With Quote
Old 04-28-2007, 06:55 PM   #12995
Default li-po mod
has anyone modified thier jrx-s for a li-po pack yet? I have and it almost brought me to tears all the cutting and grinding I had to do to the chassis to get it to barely squeese into the battery compartment.but in the end I feel it was worth the sacrifice.
wut71 is offline   Reply With Quote
Old 04-28-2007, 10:06 PM   #12996
Yeti35's Avatar
You probably just made that car really seseptable to tweak if you ground that much of it away. You probably should have just sold it the way it was and got a Type R that was designed for Lipo.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 04-29-2007, 10:41 PM   #12997
tom235's Avatar
what lipo did you get to fit? post pics
tom235 is offline   Reply With Quote
Old 05-01-2007, 05:58 PM   #12998
Default like a glove
it fit but barely.I had to battery tape the 6000mah max amps battery to the top plate and dicard the battery tray.the battery sits below the chassis at the middle bulkhead (center of car)maybe a .032 ut does not scrape at all running a 4.5mm ride height.I'll take some pics in the next couple of days and post them.
Old 05-01-2007, 10:36 PM   #12999
tom235's Avatar
why didnt you just go with the 4000 max amp it fits with out the mods
Old 05-02-2007, 05:27 AM   #13000
too late for that plus the punch you get from the 6000's
Old 05-02-2007, 05:41 AM   #13001
Yeti35's Avatar
So you feel it was all worth it to hack the car up just to get a Lipo to fit?
22 3.0SR
Old 05-02-2007, 01:12 PM   #13002
Island Losi's Avatar
would the numan setup be too soft for a brushless setup on medium to high grip asphalt track.
Island Losi is offline   Reply With Quote
Old 05-02-2007, 01:14 PM   #13003
Mike Haynes's Avatar
I'm sure it would be a good start since it was a balanced setup...if it feels too soft just stiffen it up a spring all around.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-02-2007, 02:33 PM   #13004
i don't have the bk brackets or the reviesd arms. how would this affect the setup. are the brackets easy to make?
Old 05-02-2007, 02:46 PM   #13005
Yeti35's Avatar
Save yourself the hassle and just buy some arms. I am sure your LHS can get them for you if they don't already stock them.
22 3.0SR
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
