Old 02-06-2007, 11:05 AM   #12916
Send a message via AIM to $rusty$ Send a message via MSN to $rusty$
Does anyone have a good set-up for stock carpet-foam. On a very tight track?
Rusty Andersen
thercbarn.com
$rusty$ is offline   Reply With Quote
Old 02-06-2007, 07:38 PM   #12917
losi nut's Avatar
$rusty$, go to jrxs.com and click on the forums , then go to the setups page, you should be able to find something there that works for you
losi nut is offline   Reply With Quote
Old 02-06-2007, 09:47 PM   #12918
I get an error. It's pissing me off(yes I do have a username).
Rusty Andersen
thercbarn.com
Old 02-09-2007, 08:31 PM   #12919
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Hi All
I am resetting up the car to Craig Xaviers Vegas Carpet setup and wonder how to get the rear camber to 2 degrees. The inside camber link is 5A and outside is position A on the rear Hub. 2nd question, should I run the inside or outside hole on the arm?
Should I reduce the ballcup length and then reset camber or just use the standard outside hole.
rinkrat99 is offline   Reply With Quote
Old 02-10-2007, 06:05 AM   #12920
brad996's Avatar
you can only run the inside hole in the arm if you have offset hubs that may be why that you cant get 2 degrees of camber and you may have to shorten the ball ends
SIRCS, Asylum Xtreme
TLR 22 4.0, TLR 22 3.0 lay down, TLR 22-4 2.0 Yokomo BD8/SV, Yokomo YR10F
brad996 is offline   Reply With Quote
Old 02-10-2007, 10:13 AM   #12921
TheCoolCanFanMan's Avatar
Todd, Brant, anyone really
Are the following going to be exactly the same on the Type R please
LOSA3316 Diff Bearing Acentric:JRX-S
LOSA3315 Diff Tube Alum:JRX-S
Cheers Malc TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 02-10-2007, 10:39 AM   #12922
POOKYT's Avatar
Cheers Malc TCCFM
Malc--The acentric YES....The diff tube NO
The diff tube has changed with the new style short diff assy. Hope this helps mate!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 02-18-2007, 03:15 PM   #12923
RussB's Avatar
Send a message via MSN to RussB
so my car was handling great yesterday until i lightly whacked a 4x4 barrier. i replaced the broken parts, but the steering felt "wandery" after that, specifically when powering out of a 180 degree right hander. a-arms, castor blocks, and steering knuckles all were either replaced or fine, but i didn't check hinge pins. any ideas what could be causing this?
i think i'm going to rebuild / replace the front drive shafts and tear it down again to look for anything bent.
RussB is offline   Reply With Quote
Old 02-18-2007, 06:03 PM   #12924
POOKYT's Avatar
First----Check all the bearings out of the car.
Second--Remove and cut off the shrink on the LCD's so you can pull each of the pins out.
I'm bet'n you either have a tight bearing and or a broken pin in your LCD's
Brant
Old 02-18-2007, 07:09 PM   #12925
RussB's Avatar
pooky, i think you're dead on with the LCD's. yesterday was the first time i was running lcd's on the car in a very long time. i think i'll go back to front cvd's, or maybe cvd's with the bearings on the pins.
Old 02-18-2007, 08:36 PM   #12926
POOKYT's Avatar
I had a sudden front end push last year for two races and then discovered that the pin in the LCD's had broken in the middle. From looking at them on the outside they looked perfect. I would talke my wheels off and they would feel just fine. I finnally took off the whole arm assy. and with the wheel mounted the thing would bind like a turd. Thats when I opened up the shrink on the LCD's. I do prefer to run them on the front as they are WAY MORE free for the front of the car with my spool set-up. Good Luck.
Brant
Old 02-18-2007, 11:00 PM   #12927
I B RACIN's Avatar
Send a message via AIM to I B RACIN
Default Setup
Hey guys I usually run offroad and i am borrowing a JRXS and i need a setup. Losi doesn't have anything on the website. Any help i highly appreciated.
P.S. I am running on a tight indoor asphault track.
Keith Hadley
I B RACIN is offline   Reply With Quote
Old 02-18-2007, 11:13 PM   #12928
Yeti35's Avatar
Here is a few setups and they are on Losi's site: http://www.teamlosi.com/jrxs-page/asphalt%20index.htm
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 02-19-2007, 04:53 PM   #12929
POOKYT's Avatar
Keith---Start with the Numan set-up and go from there. This has proven to be the best starting point for most of us and at most of the asphalt tracks. Good Luck!
Brant
Old 02-19-2007, 05:16 PM   #12930
RussB's Avatar
Todd, are a-arms still on backorder? Horizon had them listed as early march I believe. I sent you a PM about a problem I was having with the fronts.
I gotta get something on my car before march 3rd, it's our next points race and I only have like 1 spare arm.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
