Old 12-10-2006, 11:10 AM   #12856
Yeti35's Avatar
Originally Posted by Slippery Dan
One more question. This setup also calls for using the "offset" hole on the rear lower a-arm. But when I do this, I cannot get the top of the hub to slide in enough toward the diff to remove any postive camber. The axle is hitting the diff inside. What am I doing wrong??
Thanks.
You would have to use the offset hubs if your needing the offset position on the arms or as you have found now you can't get things to work right.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 12-14-2006, 01:28 AM   #12857
rko
rko's Avatar
Default metric/standard problem
Hi guys, had picked up a Jrx-s sometime ago but have a problem that they cant fit the hudy setup system since the hudys are metric. Dont really want to ream the setup gauges since i use them for other cars. Are there any conversions of somesort out there?
rko is offline   Reply With Quote
Old 12-14-2006, 02:04 AM   #12858
I am thinking of getting into rc. I am going to start with jrxs, and am trying to do my home work now. I can't seem to register for jrxs.com. every time I click on register it sends me to the log on page can anyone help.
Thanks,
Nate
bigguy76 is offline   Reply With Quote
Old 12-15-2006, 08:23 AM   #12859
Trader Rating: 14 (100%+)
Yeah, I have the same problem with that site.
Even when you are registered it is still buggy as heck. For instance, you will run into problems viewing setup info on there until you are "approved". I'm not sure what that process entails since no one ever got back to me about it.
It's a great info site though. Too bad the forum stuff is so glitchy.
Slippery Dan is offline   Reply With Quote
Old 12-15-2006, 09:56 AM   #12860
Mike Haynes's Avatar
The forum can be a bit strange at times, but there is some good info there as well.
It is easier to find since you wont have to look back 500 pages, lol...im sure there is more info here tho.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 12-20-2006, 06:50 PM   #12861
losi nut's Avatar
I was just on the jrxs site and came accross the JR arm and moving the rear shocks to the front of the arm, is there any benefit to either or just expirimentations? Thanks
losi nut is offline   Reply With Quote
Old 12-20-2006, 08:33 PM   #12862
POOKYT's Avatar
the JR. camber mod for me gave the car a more overall feeling of steering in, through, and out of the turns. It will help to keep the front end flatter during cornering. Plus, after I built mine I, I never broke it or had it pop off.
As for the rear shocks in front of the rear arms, this will make the car react quicker. Keith B. came up with this mod at the Birds last year. Try it and you will either love it or hate it. Always try it though. Good Luck.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 12-20-2006, 09:00 PM   #12863
Hey Pook how high can a microt jump before it explodes?
Old 12-20-2006, 09:23 PM   #12864
POOKYT's Avatar
Bout 42 feet!!
But............stay away from the brick fireplace man!!! Those tie rods are thin!!
Brant
Old 12-20-2006, 09:29 PM   #12865
How are you guys setting your droop on your car.
I think I may be setting mine wrong.
Also, after being in perfect balance most of the day, my car got tweaked after a minor collision. So much so that I have swings of 2-3 mm on ride height between the 4 corners after adjusting the shock nuts to remove the tweak.
Now I am going to disassemble the car to perhaps alleviate a chassis tweak. Should I just remove the upper chassis plates and reassemble it on a flat surface?
Old 12-20-2006, 10:11 PM   #12866
POOKYT's Avatar
Dan--Do just that and really check everything well. Usually when the JRXS has any tweak problems then something is bent or broken. One other thing to look at is the holes in the front of the chassis around where the hinge pin blocks are mounted. I have cracked one and I know a few more guys who have cracked their chassis around this point. Good Luck and let us know what you find out.
Brant
Old 12-21-2006, 04:46 PM   #12867
losi nut's Avatar
Brant
Thanks Brant, I'll make some and see how they work for me
Old 12-21-2006, 05:26 PM   #12868
When you put it all back together, assemble the center bulkheads and the 2 upper plates together first, then have the plastic bulkheads just loose enough to wiggle (attatched to the main chassis)..and screw the entire center assmbly in. Then tighten the scews under the chassis, and last put on the shock towers.
That method seemes to work the best for me.
Old 12-21-2006, 05:49 PM   #12869
POOKYT's Avatar
HEY!!!! Fart-Knocker!!!
YOU HAVE PM from like 2 days ago!!
Brant
Old 12-21-2006, 05:57 PM   #12870
Um no....dont think so, il go check.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
