Old 12-04-2006, 10:44 AM   #12841
TheCoolCanFanMan's Avatar
Originally Posted by tc4
I have seen on many peoples JRX-S's on the upper decks there is the countersunk screws with the little circle countersunk washers. What length screws do you use and what size countersunk washers do you use?
They look cool so i was thinking of doing it to my car to.
Hi TC4
Take a peak at this site its all there that you need http://www.fastener-express.com/
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 12-04-2006, 03:41 PM   #12842
tc4
tc4's Avatar
Hey Malc with your coolcanfan kits for the jrx-s how much do they cost? What would i do to buy one cause i'm in Australia?
-Corally RDX PHI
-Johnson 540!
tc4 is offline   Reply With Quote
Old 12-04-2006, 04:57 PM   #12843
Hi TC4
The JRX-S kit to OZ would be 39.99 (thats British pounds) that includes a 5 working day postage
Cheers Malc
Old 12-04-2006, 11:03 PM   #12844
Trader Rating: 14 (100%+)
Default strange offset
I got a used JRXS from a guy a few weeks ago and I just noticed that the hex hubs that the wheels bolt onto are thicker on one side than the other.
Is this a tuning technique or just an oversight on his (and now my) part?
Also, for racing, what dimension is the 190mm referring to? The width at the outside of the rims?
Thanks.
Slippery Dan is offline   Reply With Quote
Old 12-04-2006, 11:09 PM   #12845
Hey Dan usually I use the thicker hubs up front and the thinner ones in back. Having the thicker ones to one side may have been a tuning feature for oval?
The 190mm measurement is to the outside of the wheels. The car will have to fit into a wooden "box".
jeffb is offline   Reply With Quote
Old 12-05-2006, 07:33 AM   #12846
Gupy's Avatar
On the same topic, what's the effect of running offset front and rear wheels?
Mike Haynes,
I know your rubber setup that you've been lending out calls for narrower layout in the rear. I tried making this work, but ran into some problems with the drive shaft bumping into the diff nut inside the left outdrive. Lots of room on the right though. Is there something I'm missing?
Gupy is offline   Reply With Quote
Old 12-05-2006, 08:24 AM   #12847
Mike Haynes's Avatar
If you use the inner hole on the arm for the rear hubs, you need to use an offset hub...they are sold seperately in 0, .5, and 1 degree toe amounts.
Sliding the regular hub into the offset hole on the arm will not work.
For the hexes, it was explained to me that a narrow hex in the front will make a car steer more, sort of like a tricycle...but a wider hex will reduce the rim rubbing on the shock bottom, and allow you to use more d/r. Try both and see what works for you. I try to run the front and back of my car at the max width allowed (190). Different brand rims have different offsets, so which hex you use may change if you switch brands frequently. With Parma, a wide front and narrow rear will be maxxed out. If you use Speedmind or Jaco you can use the wide hexes in the rear also, as they have less ofset to them.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 12-05-2006, 11:59 AM   #12848
Gupy's Avatar
Thanks again Mike! I assume these offset hubs are listed with the older XXX-S hubs (compatible I think)? Can't seem to find a part number for the Jrx-S.
By the way, I've had some front arms on backorder at my local hooby shop for what seems like forever. Looks like even Losi Parts House.com doesn't have any in stock. Anyone have some insight?
Cheers!
Old 12-05-2006, 12:04 PM   #12849
http://www.horizonhobby.com/Search/D...d=&PageSize=72
Go there for the hub part #s.
You would have to ask Todd about the arms.
Old 12-05-2006, 03:46 PM   #12850
Dreddlox's Avatar
Stormer hobbies usually has them in stock, you can try them.
Dreddlox is offline   Reply With Quote
Old 12-06-2006, 04:18 AM   #12851
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Hey guys,
I am picking up a second hand JRXS and was wondering what would be a good setup for stock on a low grip tight ashphalt track. Would kit settings be good?
Cheers
Fast XXXS is offline   Reply With Quote
Old 12-08-2006, 10:37 PM   #12852
Mike, I left you a PM. I had a couple of questions about your setup that you sent me.
Thanks.
Old 12-09-2006, 11:07 PM   #12853
How do you adjust the toe-in on the rear??
Old 12-10-2006, 12:01 AM   #12854
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
You can either use differnt rear piviot blocks or you can use rear hubs with built in toe.
Kave is offline   Reply With Quote
Old 12-10-2006, 09:49 AM   #12855
So if I have a setup that calls for a 0 degree pivot on the rear then I would need to use 2 degree hubs, right? I can't seem to find any of these hubs though. I even looked at xxx-s parts.
Does anyone have a part number for these?
One more question. This setup also calls for using the "offset" hole on the rear lower a-arm. But when I do this, I cannot get the top of the hub to slide in enough toward the diff to remove any postive camber. The axle is hitting the diff inside. What am I doing wrong??
Thanks.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
