Old 11-17-2006, 10:15 PM   #12796
Bink's Avatar
Yeti35 - try the CraigX carpet setup on page 422. Craig's setups work well for me.
Bink is offline   Reply With Quote
Old 11-17-2006, 11:36 PM   #12797
tom235's Avatar
thanks mojo i will give it a try are you running the numan set-up just with heavier oil
ya yeti try the foam set-up i can see if it works or not
tom235 is offline   Reply With Quote
Old 11-18-2006, 06:33 PM   #12798
Trader Rating: 14 (100%+)
replacement for black bladder
I have a setup sheet that calls for black shock bladders but I overlooked this and did not order any before this Sunday's race.
Now I only have the white bladders.
The setup calls for black bladders/white o-ring in the front and black bladder alone in the rear.
What difference am I going to feel in the front with these and is there some way to fudge the results (an extra o-ring or something)
Slippery Dan is offline   Reply With Quote
Old 11-18-2006, 06:38 PM   #12799
Mike Haynes's Avatar
If you add an extra white o-ring above the white bladder it should feel similar to a black.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 11-18-2006, 08:47 PM   #12800
Thanks. Off to install it now.
Old 11-18-2006, 09:33 PM   #12801
Capelracer's Avatar
Originally Posted by Gupy
Anyone running a CO27 on rubber with the JRXS? If so, what pinion are you running compared to a Monster? BTW, I'm running the stock ratio with the 118 spur.
I'm running 90 spur 26 pinion (changed to 48pitch as I had a heap of 48p pinions) with 3800's & takeoff cs-27's for my co27pro - interestingly this gearing was optimum for my track when I ran a komodo!
Capelracer is online now   Reply With Quote
Old 11-18-2006, 10:08 PM   #12802
Where can I get the black shock bladders? All I see on Losi's part list are the stock white ones.
Old 11-18-2006, 10:23 PM   #12803
LOSA5328 10M SERIES FIRM BLADDERS (4) JRX-S
losipartshouse.com
jeffb is offline   Reply With Quote
Old 11-19-2006, 12:03 AM   #12804
mojoman's Avatar
Originally Posted by POOKYT
Your running a Spool in the front, and the one-way pulley in the middle?
How does the car react under braking? I would like to try this too, but I was concerned the braking might be sketchy. Also, are running stock-19 turn- or mod? Later man.
Brant
Just dial in a little drag brake in the radio. Off power it gets somewhat pushy. I can compound about 1/8 of the front tires and mid corner lay into the throttle without a problem. If there's enough front toe you should be fine. I'm running stock.
Originally Posted by Yeti35
I got a ?? for Todd or whoever wants to answer. Was there ever a real good carpet setup for this car w/ foam? I am talking box stock JRXS with only mod being the new arms. We are opening a carpet track here in UT and I never worried about a setup before since I ran nothing but rubber. When the new car comes out I will regulate this one to rubber only for I like it that way but want to try a foam setup till it comes out. Would be nice if it is a downloadable PDF or similiar so I can print it out. Thanks to anyone who replies.
Matt Howard has a good general starting point and is looking for feedback at this link . It was a good place to start for a newbie on foams as I am.
Peace,
C
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 11-21-2006, 07:16 AM   #12805
Trader Rating: 31 (100%+)
Default Good set-up
Hi guys. I'm looking for a good starting set-up for my JRX-S on med bite asphalt with rubber tires, any help or direction will be greatly appreciated.
$$$... is offline   Reply With Quote
Old 11-21-2006, 07:26 PM   #12806
POOKYT's Avatar
Go to the Losi or JRXS.com sites and find the Numan set-up. It is the main stay of set-ups for this car on rubber tires. Follow the set up exactly and you will be very close if not dialed the first time out. Good Luck!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 11-21-2006, 07:53 PM   #12807
Yeti35's Avatar
I will do you a favor since Pookyt wouldn't!! http://www.teamlosi.com/jrxs-page/asphalt%20index.htm
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 11-21-2006, 08:34 PM   #12808
Thanks for the help... will give it a go. I've never run with a spool though, only diffs and one-ways...
Old 11-21-2006, 10:05 PM   #12809
should i buy a jrxs??? been finding good deals on em cuz the R is comin out.....so buy the jrxs or wait and get the R????
DotyThe8ight is offline   Reply With Quote
Old 11-21-2006, 10:19 PM   #12810
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
get the R" reason for that it is the latest new car and handle well for mod motor....Jrxs works great for stock and maybe 19t motor....
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
