Old 11-16-2006, 11:58 AM   #12781
Gupy's Avatar
Playing with the suspension on my Jrxs. I'm running stock rubber on carpet and I've got a set up that Mike Haynes posted (Thanks Mike!). What are the effects of moving to the #56 pistons and black bladders?
Thanks!
Gupy is offline   Reply With Quote
Old 11-16-2006, 12:02 PM   #12782
Mike Haynes's Avatar
What do you have in it now?
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 11-16-2006, 12:09 PM   #12783
Trader Rating: 6 (88%+)
just got a phone call i will have the new one DEC 10th
told you mike
comming soon MOTORHEAD RC MOTORSPORTS...........
BILL.D is offline   Reply With Quote
Old 11-16-2006, 12:19 PM   #12784
Gupy's Avatar
Presently I've got what comes out of the box (#60 and white bladders?).
Old 11-16-2006, 01:24 PM   #12785
Your car will stick to the track better with the 56's...the 60/57 with the BK arm position will make it feel like your driving on a cloud. The blacks feel like a white with an oring above, but they let the shock go up futher without hitting th bladder, so you won't have to cut the shafts shorter.
Hope that helps.
Old 11-16-2006, 01:36 PM   #12786
Gupy's Avatar
Thanks for the tips Mike! BTW, just learning some of the terminology here ... when you say 60/57, is this front/rear shock lengths? And the BK arm is that the new arms with the additional mounting locations?
Cheers!
Old 11-16-2006, 01:37 PM   #12787
60/57 i was reffering to the included pistons...No problem
Old 11-16-2006, 02:20 PM   #12788
Gupy's Avatar
Does anyone have the instructions for mounting the BK brakets that I could get, if they come with some. I only recieved a bag with the parts but no pics or instructions. Thanks
No real need for those anymore since the new arms are out with that mount already molded into them.
Ok, up to speed on the lingo.
Thanks again!
Old 11-16-2006, 10:48 PM   #12789
tom235's Avatar
Originally Posted by Yeti35
Team Tweaker on the move again!!
yep thats me i can't help it. i just have to mess with it
tom235 is offline   Reply With Quote
Old 11-17-2006, 06:20 AM   #12790
mojoman's Avatar
Originally Posted by tom235
hey pookty i have a tech queston for ya what will the center oneway do for you with a spool in the front,and whats the advantage or is there.
That's my winning combo!! I run a one way spool on a very high bite asphalt track. The suspension is pretty stiff (50 lb springs in the front 30 in the rear) but I get out of the corners like a rocket. My toe is at .5 in the front and 2 in the rear. I can get away with a lower ride height due to traction, maybe that's why it works so well for me.
Peace,
C
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 11-17-2006, 08:52 AM   #12791
Yeti35's Avatar
Peace,
C
Well Tom, there you got. I thought it would be a really weird combo but mojo says otherwise. Sounds like a combo that may work up here on the asphalt since it is pretty high bite.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 11-17-2006, 09:47 AM   #12792
Gupy's Avatar
Anyone running a CO27 on rubber with the JRXS? If so, what pinion are you running compared to a Monster? BTW, I'm running the stock ratio with the 118 spur.
Old 11-17-2006, 10:00 AM   #12793
Yeti35's Avatar
They say two to three teeth higher on pinion then a monster. I ran one once but don't remember what gear I used. I did not quit running because I did not like it, just not much stock racin goin on at my track this past summer and when I went to IIC it was a monster handout. Hopefully someone that is still running it will give you some insight.
22 3.0SR
Old 11-17-2006, 11:49 AM   #12794
Yeti35's Avatar
I got a ?? for Todd or whoever wants to answer. Was there ever a real good carpet setup for this car w/ foam? I am talking box stock JRXS with only mod being the new arms. We are opening a carpet track here in UT and I never worried about a setup before since I ran nothing but rubber. When the new car comes out I will regulate this one to rubber only for I like it that way but want to try a foam setup till it comes out. Would be nice if it is a downloadable PDF or similiar so I can print it out. Thanks to anyone who replies.
22 3.0SR
Old 11-17-2006, 05:40 PM   #12795
POOKYT's Avatar
Peace,
C
Your running a Spool in the front, and the one-way pulley in the middle?
How does the car react under braking? I would like to try this too, but I was concerned the braking might be sketchy. Also, are running stock-19 turn- or mod? Later man.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
