Old 10-18-2006, 08:15 PM   #12691
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
thank you guy. i just got the jrxs i know its a little latE trying this car out. but im just curious of the layout. if i like it then i might ditch 007 and go for the R.
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 10-19-2006, 12:38 AM   #12692
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Welcome!!.............. You won't be disappointed!!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 10-19-2006, 02:30 AM   #12693
TheCoolCanFanMan's Avatar
I second that one.
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 10-19-2006, 01:06 PM   #12694
pinggoy's Avatar
thank you guys. i know i can count on you guys if i got question...
TAMIYA TRF416X
Old 10-19-2006, 05:02 PM   #12695
pinggoy's Avatar
will there be someone here who could share a setup for asphalt (med to high bite, tight) track. using a diff.
thanx
TAMIYA TRF416X
Old 10-20-2006, 09:04 PM   #12696
Default Mikes setup
Hello, I am going to try using mikes setup and I have a couple questions about it if Mike or someone else can help. This is the IIc rubber setup. With the front mod camber links you have to space out the front shocks so they have clearance from the links. How many degrees of steering do you get like this? It seems like you dont get much steering before the wheel hits against the shock. Maybe it is enough,I havent got to the track yet to try it. Thanks
Jack B is offline   Reply With Quote
Old 10-20-2006, 11:36 PM   #12697
Mike Haynes's Avatar
For the most part i shaved the camber mod itself to make sure nothing rubbed ex..shocks and wheels. I was able to get full lock without any issue.
These are the only pics i have of it (a few months dated), but if it dosn't help i can take a new pic later this weekend.
The only real change is i use a set screw instead of a socket head screw now to hold the ballcup end on.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 10-20-2006, 11:44 PM   #12698
A_Stratus's Avatar
I was wondering if anyone is using Keith Billanti's rear shock mod? If so, how do you like it? What advantages do you feel you now have over the stock shock location?
Also are you still using it Keith?
Thanks,
Aaron
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 10-20-2006, 11:45 PM   #12699
pinggoy's Avatar
i searched the pages way back and i saw still bill's steps on umaking the link mod.but with out pic and alot off side talk.. i cant really follow.. im not really in desparate need for this but is someone is kind enough to tell me the steps on it. just plain and simple steps. or if some one can just sell me one so i can try it out. thanx..
TAMIYA TRF416X
Old 10-21-2006, 07:36 AM   #12700
Yeti35's Avatar
Unless you are in a big hurry to try this mod, just wait till the new car comes out for Losi is putting this option on it. They are manufacturing the part so you don't have to. I personally like the Numan setup for rubber on carpet and it works pretty well imo. The mod should be useable on the old car once they make the parts. Some stuff will be interchangable.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 10-21-2006, 07:38 AM   #12701
Kwikvdub's Avatar
I agree!
Alex Valdes
Old 10-21-2006, 11:32 AM   #12702
tom235's Avatar
has anyone tryed to put the carbon 3200 lipo in there jrxs and does it fit or did you have to mod it to get it to fit
Tom
tom235 is offline   Reply With Quote
Old 10-21-2006, 03:23 PM   #12703
pinggoy's Avatar
guys just got my first jrxs. this is the first time i have seen in my own eyes. a jrxs. since most people run xray in our track and i run yokomo bfore.. it looks so good and the drive train is soo free. cant wait to test it out on the track... how you guys build the spool? just take the balls off and put the sand paper up against the diff rings? do i have to glue it down or not? does it really holds down? what are the parts the wear out or damge easily with the spool exept the outdrive? thanx..
really? thats awsome. it i like the run on this car i might buy one..(jrxs-r)
TAMIYA TRF416X
Old 10-21-2006, 03:54 PM   #12704
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Thanks,
Aaron
It made the car transfer weight forward faster. I think it is only somthing to try in really high bite situations.
I am not running it as I want to try to run what the whole team is running on the car,, the 6 heads is better than 1 theory.. didnt work too good in vegas LMAO I am also running the new diffs which allow the car to transition better everywhere. It is not going to be an option on the new car.. and nor will it be necessary.
I did find that Smykas setup suited me well... car felt good. Hopefully, we (the guys running the FMC) will have somthing for everyone to try after the classic this comming weekend.
KB
OUT
Keith Billanti is offline   Reply With Quote
Old 10-21-2006, 05:29 PM   #12705
A_Stratus's Avatar
My home tracks layout is getting changed over to a new layout so traction won't be fully there for a little bit bit I'm definately going to try your mod out when the traction is fully up. I will let you know how I like it. Thanks for the innovative idea.
Aaron
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
