Old 09-17-2006, 10:36 PM   #12556
Yeti35's Avatar
Originally Posted by rcracingkid
No problem, how many guys are running the mid motor car at Vegas?
I will be runnin two of them and I am pretty sure Pooky is runnin one as well. There will be others there I would imagine.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 09-18-2006, 02:46 AM   #12557
TheCoolCanFanMan's Avatar
Originally Posted by POOKYT
I thought they were .050's and .030's? Anybody know for sure?
Brant
Now you got me wondering myself I will be re-building the car this week and will use my trusty vernier to see what they come out at
Cheers Malc THE CAN MAN
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 09-18-2006, 05:47 AM   #12558
POOKYT's Avatar
Hey Malc!!!! Howz bout we just refer to them as the "thick" and the "thin" shims ??!! Sems like I remember checking mine some time ago and they came out to be .052 and .038. I measured several different shims and they varied a bit. It seems the edges were thicker on some than others. AHHHHH!!! Just bolt them down and run'em!!!
Brant
l
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 09-18-2006, 05:48 AM   #12559
POOKYT's Avatar
Yup! I will be running the std. JRXS this week in Vegas.
Brant
Old 09-18-2006, 08:05 AM   #12560
Brant
l
now theres an idea
Malc TCCFM
Old 09-18-2006, 08:08 AM   #12561
Brant
Hey Brant, is there going to be a live feed from Vegas ? if so, could you find a link
Cheers Malc TCCFM
Old 09-18-2006, 08:46 AM   #12562
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
I ran it today in practice while i was racing foam, we had a nice groove and it got better, still a slight slide but consistent and it will only get better with more grip.
Also, i will post my current foam setup, it felt really really good today. Hope it can help someone
Thanks Mike, Good Luck in Vegas!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 09-18-2006, 09:09 AM   #12563
Mike Haynes's Avatar
Alex, better get your touring car ready to go, after your run in 12th, you need to race touring as well
The car was great in the main, and thats how it was setup, should be hooked up for you as well, it was very stable and still had steering / plenty of cornerspeed.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 09-18-2006, 10:03 AM   #12564
Kwikvdub's Avatar
Your car looked planted and looked liked it rotated very smoothly with plenty of corner speed. Impressive win!!..............
................. And you were worried about the start of the race .........
Alex Valdes
Old 09-18-2006, 04:15 PM   #12565
Juan Valdez's Avatar
Mike, thanks for posting your set-up. Definatly food for thought. I had a couple questions, thought:
1.) 3 deg rear toe-in with off-set hubs? Could you explain the reasoning for this? Would using standard hubs with less toe-in be similar?
2.) Using the BK bracket on the inside position of the rear arms. Explaination? Would using a 10.5 lb spring and lighter oil in the outer hole on the arm be similar?
Not doubting the set-up, just want to understand the reasoning as it is a little "unconventional" compared to the other set-ups I've seen. Just trying to learn when I may want to try these changes. Thanks!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 09-18-2006, 06:05 PM   #12566
The 3 degrees is to make the car launch straighter, i was having a problem with oversteer on power...i would have went to regular diff grease or ditched the anti dive, but then it became to twitchy into the corner. The offset hubs along with the sway bars was to keep the car from having a ton of roll, and try to get more corner speed. The bk bracket on the inner hole was basically to get the shock more upright, again mainly for on power keeping the rear planted, the 10lb spring in the regular location seemed to be a little unconsitent when traction came up.
I really don't have solid theory on the "different" stuff, just what i prefered on the track. Like i mentioned, we have a decent amount of bite on the track now compared to when i started practicing rubber, and the car seems to just get better now with out any changes.
ALSO, i fogot on both setups to note that i have the middle 2 chasis standoffs out. The rearward pair is still installed. I did this to help the car grip better with just a little more flex. I happen to be fond of the feel, as well as one buddy of mine, but another person at my local track isn't at all, he likes the car better with all standoffs, so it is something to try when you have a chance, probably not while practicing at a big race.
Any input is welcome
Old 09-19-2006, 09:03 AM   #12567
Mike, thanks for the explanations! You've definatly given me some things to think about and try. And I don't question your set-up being different than the "norm." I've been doing my own thing set-up wise most of the time I've had this car as a lot of the posted set-ups just didn't seem to work the best for me. Ya gotta experiment to learn!
Old 09-19-2006, 09:28 AM   #12568
Kwikvdub's Avatar
Never hesitate to ask. He is truly dedicated to this car. I race with him and his car is truly perfect out there.
Good luck with your winter race program this year and let us know how your set-up is doing.
Happy Racing!
Alex Valdes
Old 09-19-2006, 11:41 AM   #12569
smyka's Avatar
Send a message via AIM to smyka
alex if you ever want to try a different set up give me a shout my car is really easy to drive and hold a ton of corner speed ..
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 09-19-2006, 11:59 AM   #12570
robsxxxs's Avatar
thanks for the set up last week for ashphalt! but now we have our big carpet race comming up and i need a set up for it. "Stock Rubber". i used a set up i found on losi's site for carpet racing last year but i didn't like it, the back end was way to loose, always wanting to rotate around.
AE FT TC5
Losi 8ight B
Losi 8ight T
Losi XXX MF2
AE FT T4
Tamiya 415 MSX
Losi JRXS
Losi XXXS
robsxxxs is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
