Old 09-10-2006, 10:38 PM   #12526
Still Bill's Avatar
Originally Posted by POOKYT
The bearing rear drives do alow for more body roll and a slightly loose rear end. They do not have the friction that the standard pins in the outdrives have. The same goes for the fronts. The more friction your drive shafts have the flatter that end of the suspension will be. If you think the freeness is too much then you can compensate by a small chassis change in roll center blocks or camber links. Personally, I prefer to have too much and then tune it out than to get into a circumstance where I need more but cannot get it. Hope this makes sense! LOL It sounded better in my head than when I typed it!!
Brant
But, your spelling and grammar are purrrrrrrfect. That school teacher wife must be helping.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is online now   Reply With Quote
Old 09-11-2006, 12:50 AM   #12527
POOKYT's Avatar
LMAO Well, she keeps trying to "learn" me better but I'm not sure how its going!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 09-11-2006, 12:52 AM   #12528
POOKYT's Avatar
Originally Posted by Yeti35
So what time are we getting together for refreshments next Tuesday? If it was said, I forgot.
I was thinking it was around 6:00 or 7:00. Sometime after registration is over. We may need a roll call here to see when everybody will be arriving.
Brant
Old 09-11-2006, 01:19 AM   #12529
FlyinRazorback's Avatar
Send a message via AIM to FlyinRazorback Send a message via Yahoo to FlyinRazorback
Brant knows I'm watching over his shoulder for any spelling or grammar mistakes.
C.V.R.C. Offroad, Southaven, MS
RC8.2E, Tekin, Airtronics
FlyinRazorback is offline   Reply With Quote
Old 09-11-2006, 04:18 PM   #12530
POOKYT's Avatar
Heck I don't even need SpellCheck since I have you fellas on here!!! LMAO
Brant
Editor
B-Main Motorsports
Old 09-12-2006, 11:55 PM   #12531
robsxxxs's Avatar
i am looking for a good set up for my jrxs. i need it for stock ashphalt i dont have time to go through 400+ pages. as of right now i am using the neuman set up but i am very loose in the back still. any help is appreciated.
AE FT TC5
Losi 8ight B
Losi 8ight T
Losi XXX MF2
AE FT T4
Tamiya 415 MSX
Losi JRXS
Losi XXXS
robsxxxs is offline   Reply With Quote
Old 09-13-2006, 12:20 AM   #12532
POOKYT's Avatar
Stand up the rear shocks to the outside hole and try it. If its better but not as consistant as you like then lean the shocks back in 1 hole and move the camber link to the #5 hole. Better but still a bit loose then raise the link to the #2 hole. If your track is very loose or the above changes are still not enough then return to the original positions on the shock and camber link but add the thin shim under the suspension blocks to raise the roll center. Try it again and repeat the first changes to fine tune it. Good Luck
Brant
Old 09-13-2006, 03:00 AM   #12533
TheCoolCanFanMan's Avatar
This ill have the cars backside stuck to the grond for sure, I have used it for the last 6 months and have not hardly deviated from it
Ben Rayments set-up
Front:
50wt Oil
15lb Spring
56 Piston
White bladder
2 O-rings above bladder
2mm droop
4 degree caster
1 degree camber
41T spool
.100" shim under high roll center
diff high
middle hole on shock tower
position 5 on camber link - JR Camber link mod, rear tower on the front see:
http://www.rctech.net/forum/showpos...postcount=10792
and
http://www.rctech.net/forum/showpos...postcount=10354
Rear:
35wt Oil
12.5lb spring
56 piston
White bladder
3mm droop
1.5 degree camber
.040" shim under low roll center
diff high
2 degree inboard toe-in
hole 2 on shock tower
hole 5 camber link
any ballast weight at rear of car (as close to the diff centre line as poss.)
If I've missed anything, email me.
Cheers Malc THE CAN MAN
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 09-13-2006, 07:37 AM   #12534
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
I'm running a very similiar set-up as Malc and the car is very easy to drive and feels planted........ If you want the rear more planted, use a 10.5lb. spring in the rear............ Other than that, my set-up is very similiar.
Enjoy and let us know how it feels.
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 09-13-2006, 12:19 PM   #12535
Yea the car feels planted as Kwikvdub says, and strangley enough I went to 10.5 springs as the track we was at the weekend was a little more bumpy than other tracks I had been going to. I also stood the rear shocks ringht up but made the car bog down on the rear. A mate of mine ran the same set-up but instead of going with a softer spring went to 30 weight oil in the rear which seemed to work better, he also had bump steer as per the manual (apparentley) when building the car you have that option, .....missed that one, but his car was far more quicker through the chicanes. but he is only 20 and me well ............
Old 09-13-2006, 07:55 PM   #12536
RandyB's Avatar
ok.... so why cant I veiw jrxs.com ? is this site still up.
RandyB is offline   Reply With Quote
Old 09-13-2006, 08:00 PM   #12537
Kropy's Avatar
Send a message via AIM to Kropy
My guess is that your just a tart
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 09-13-2006, 08:58 PM   #12538
POOKYT's Avatar
It works fine for me. Once you get to the first page you must click on the JRXS.com logo.
Brant
Old 09-13-2006, 11:20 PM   #12539
tom235's Avatar
do you shave your shims down? or are there other shims out there
tom235 is offline   Reply With Quote
Old 09-13-2006, 11:29 PM   #12540
Yeti35's Avatar
????? WTH you talkin about?
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
