Old 08-26-2006, 02:13 PM   #12481
mooony's Avatar
Originally Posted by tom235
are your belts tight?
yes. they have about 3-4 mm up and down movement.
Ronald
mooony is offline   Reply With Quote
Old 08-26-2006, 02:57 PM   #12482
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Originally Posted by POOKYT
Todd--Has anyone tested the new diff parts in a front motor chassis?
Brant
hmmm not a bad idea.
OUT
Keith Billanti is offline   Reply With Quote
Old 08-26-2006, 04:11 PM   #12483
POOKYT's Avatar
Ronald
Ronald--The noise is from the belts skipping a little bit. Try tightening the belts a little more and the noise will lessen. Some belt skipping is normal, at least with mine anyways. Good Luck and let us know what happens.
Also, last race day for me I have a grinding noise and I traced it down to a SINGLE GRAIN of sand stuck between two teeth in the spur gear. After I went around the spur like 5 times I finally found it and removed it with my Xacto blade.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 08-27-2006, 01:43 AM   #12484
mooony's Avatar
Brant
Thanks for your reply. I wil try and tighten the belts some more.
Thanks Again.
Ronald
Old 08-29-2006, 07:56 PM   #12485
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Any of you guys who run Numan's setup on carpet with rubber tires, do you use swaybars at all or not? Any deviations from the standard asphalt setup to note? I'm running stock rubber on CS27 spec tires, with a Protoform Mazda 6 and the entire Numan asphalt setup if that makes a difference. I have never had the car on carpet, and I'm honestly a bit skeptical that the outdoor setup is going to be an exact match to the carpet setup.
Just making sure I have all of my ducks lined up...
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 08-29-2006, 08:25 PM   #12486
Yeti35's Avatar
I ran that setup on both of my cars last year at IIC and used no
sway bars. I have a complete set for both cars but have never used them. I ran nothing but rubber on carpet there. Mazda 6 body works fine too. Apparently if you run rubber on carpet you use what ever works for you on asphalt for a setup.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-29-2006, 09:06 PM   #12487
Suspended
The Numan setup on carpet is really close. I changed the rear end a bit as it can get a little loose on power out of corners. I moved the camber links to the middle row center position and moved the shocks out one hole on the shock tower. The rear end in planted now.
RacineRacerrr is offline   Reply With Quote
Old 08-30-2006, 04:43 PM   #12488
Johnny Wishbone's Avatar
Default BooooHooo
Remember when we used to be on the first page of the forum.
Old 08-30-2006, 04:50 PM   #12489
cannon's Avatar
Trader Rating: 35 (100%+)
Thats when people thought it might be a good car ... now they have learnt better
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 08-30-2006, 06:53 PM   #12490
Still Bill's Avatar
Alas...Sooooooooo true, so true...Wish you guys the best of luck with that.
Where's PookyT to move things upward???
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-30-2006, 06:56 PM   #12491
JAY_UK's Avatar
Send a message via MSN to JAY_UK
I was on there as losi_g+, dont ell me, new car s out in 2 weeks??LMAO
JAY_UK is offline   Reply With Quote
Old 08-30-2006, 06:56 PM   #12492
POOKYT's Avatar
This just means we have to share with the new thread!! Thee is room for both!
To the Top!!!!
Brant
Old 08-30-2006, 07:01 PM   #12493
Still Bill's Avatar
It is a good car for "expert" conditions...as it is billed as being.
Old 09-01-2006, 11:22 AM   #12494
tom235's Avatar
well i got the car pretty much done for the race sat. i hope its worth switching? but were going to give her a shot its been a rocky start
tom235 is offline   Reply With Quote
Old 09-01-2006, 05:11 PM   #12495
POOKYT's Avatar
You will be fine with it. Just remember that this car only likes to be driven as fast as the set-up allows. Its not the best if your on the edge and trying to push it. Its is very fast but you have to get a set-up that suits you as well. Good Luck!
Brant
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
