Old 08-12-2006, 09:37 AM   #12361
POOKYT's Avatar
Originally Posted by Yeti35
Your pack may be ok but if you are usin the Corally plugs you may want to set your packs up like the one in my pic. If that pic does not help you let me know and I will get you another one that shows how the connectors sit low between the cells. I just thing it will be too hard the way it is set up in your pic to attach the wires since you will be close the the belt and top deck.
Ok,mental note................Yeti is packing 1.212 cells so I need better batts in Vegas......................
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 08-12-2006, 10:03 AM   #12362
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by POOKYT
The standard pulley has 42 teeth. The over drive pulley which we use normally in the spool is 41 teeth. Other than just the slight smaller diameter, the 41 tooth pulley has black slash marks on one side of it. When I died mine the black mark did not go away so you may be in luck. Other wise start counting teeth!
Brant
Did you use Rit to dye the diffs? Did you have a problem with warping?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 08-12-2006, 11:02 AM   #12363
POOKYT's Avatar
Originally Posted by PitNamedGordie
Did you use Rit to die the diffs? Did you have a problem with warping?
Yup! Rit dye is what I used and no problems with warping. I also used the Rit dye for my front belt but I only dipped it in several times so I wouldn't melt it. Take your time and keep pulling the parts out often to see their progress.
Brant
Old 08-12-2006, 04:52 PM   #12364
Yeti35's Avatar
Originally Posted by ttso
Wo thanks lots Yeti. I think now I'm more ready for rear motor JRXS...
I am not sure how the battery layout will be for the rear motor car I only run the front. Not Losi sponsered at all. I thought you were askin if your pack is good for the front motor car and my pic is how I have my packs set up for it. I can look at Hodges car in LV and let you know after that, unless he pokes his head in here and makes a reply!!
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-12-2006, 04:54 PM   #12365
Yeti35's Avatar
Brant
That is good if you want to be better then my 38's. I am packin 42's now!! I would show you the numbers on them but I would have to kill yah!! If you want what I got the link is in my sig and tell them Yeti sent yah.
22 3.0SR
Old 08-12-2006, 05:21 PM   #12366
POOKYT's Avatar
HEHEHEHEHE.... .......Pooky is packing some 4200's too!!!!
Brant
Old 08-12-2006, 06:30 PM   #12367
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Brant
30 amp 2.212's though . . : )
Old 08-12-2006, 06:43 PM   #12368
tc4
tc4's Avatar
I have 1.215v IB3800 but the are 30amp. What would the be acwivalent (I think thats how you spell it) to if they were 35amp?
-Corally RDX PHI
-Johnson 540!
tc4 is offline   Reply With Quote
Old 08-12-2006, 06:45 PM   #12369
Matt Howard's Avatar
Go me! I TQ'd and won mod TC at our Roar region 8 onroad champs today with my JRXS.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 08-12-2006, 08:53 PM   #12370
POOKYT's Avatar
Way to roll it Matt!!!! Good job!
Are you going to Vegas as well?
Brant
Old 08-12-2006, 08:55 PM   #12371
2-Bad's Avatar
Trader Rating: 24 (100%+)
Post
From the Promatch site......
Example: 1.220 @ 30 amps = 1.205-1.210 @ 35 amps
Seconds at Seconds at
30 Amps / 35 Amps
495 / 420
500 / 425
505 / 429
510 / 433
515 / 438
520 / 442
525 / 446
530 / 451
535 / 455
540 / 459
Oh... and it's "equivalent"
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 08-12-2006, 10:10 PM   #12372
POOKYT's Avatar
What if you have 4200's at 1.234 at 35 amps?
Brant
Old 08-12-2006, 10:13 PM   #12373
Mike Haynes's Avatar
Brant
Then we get to hit the pipe with major authority
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 08-12-2006, 10:17 PM   #12374
POOKYT's Avatar
LOL Well I'm glad I'm not the only one to do it too. LMAO
Brant
Old 08-12-2006, 10:21 PM   #12375
Brant
No vegas for me this year, going to N.Y.C for my sister in laws wedding that weekend.
RCTech #361
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
