Old 06-26-2006, 04:09 AM   #12001
TheCoolCanFanMan's Avatar
Originally Posted by Randy Caster
I havent run TC4 hubs, but TC3 hubs using the A hole and 7 or 8 camberlink on the shock tower gives a lot of rear traction.
Sometimes to much rear traction and not enough rotation, but I dial it out by taking the rear tyres off
Cheers Malc THE CAN MAN
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 06-26-2006, 10:08 AM   #12002
Juan Valdez's Avatar
Hey Randy, can you explain this? Just to be clear, your saying using the TC3 rear hubs provides more rear traction than the stock Losi hubs? What exactly do they do? Change the roll center? Allow for a longer rear camber link? Just curious because I've been trying to get a little more rear traction (running mod rubber on asphalt for the first time this summer). Thanks for the help!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 06-26-2006, 01:43 PM   #12003
Andrew Gray's Avatar
Originally Posted by Yeti35
I am thinkin the rear motor car should be no different in the respect that you really can't use the Lipo batteries for the don't fit in the battery compartment. If I am wrong I am sure someone will correct me. There was a couple of guys here that got rid of their JRXS's for that very reason. I don't feel that is a valid reason for getting rid of a good car but whatever.
The production rear motor car will be Lipo pack friendly.
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Old 06-26-2006, 02:18 PM   #12004
Drew PM sent
crazycraig is offline   Reply With Quote
Old 06-26-2006, 03:02 PM   #12005
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I havent actually measured the difference in where the camber link mounts, but the A hole in the TC3 hub is lower and further inward than the A hole in our hub. I havent tried using them with the middle row (4, 5, and 6) on our shock tower as I believe it wouldn't have any camber gain because of how low the link mounts on the TC3 hub. They fit in pretty easilly, you just have to file a little material off of the area where the hingepin goes through to get them to fit in our arms.
Old 06-26-2006, 04:04 PM   #12006
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Out of curiosity, what is used as the C-hub in the JR front link mod? Is there a different hub that is used? I don't see how that works making that hub out of two different pieces...
Is that a hub from another Losi car?
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 06-26-2006, 04:22 PM   #12007
The cut down C-Hub is just a 0 degree Losi hub.
Old 06-26-2006, 04:41 PM   #12008
squarehead's Avatar
Is there an upper hinge pin location on the 0 hub? All of the front hubs I have are ball end tops... I'm not seeing it.
Everything depends.
Nothing is always.
Old 06-26-2006, 04:51 PM   #12009
squarehead's Avatar
This circled area is NOT part of a normal 0 hub from a JRXS...
I have seen a few that looked like they were glued or epoxied together, but there's no way I put a car on the track with glued suspension components.
Everything depends.
Nothing is always.
Old 06-26-2006, 05:12 PM   #12010
Thanks Randy. I may have to give this a try this weekend.
Has anyone tried running more than 2 deg of rear toe-in on this car? If I remember right, this should help the rear tires remain planted better on-power coming out of a corner. Correct?
Old 06-26-2006, 05:18 PM   #12011
Doug - I believe JRXS-Bill posted a step-by-step how-to for making the JR-links a couple of months back, pictures and all. You could try searching the thread. Basically, the part you are looking at is the very bottom portion of a 0 deg C-hub (Losi or Associated). Instead of installing a ball stud into the c-hub and knuckle, you screw this 0-deg hub bottom to the top of what ever standard c-hub you are using. Try searching for JRXS-Bill's how-to post. It did a pretty good job explaining it.
Old 06-26-2006, 05:46 PM   #12012
Mike Haynes's Avatar
I have run more, but its very rare that you will need to....you are correct tho, more rear toe made my car plant better out of the corners.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-26-2006, 05:47 PM   #12013
squarehead's Avatar
Thumbs up
Thanks, I found it now. Post numbers 10354 & 10355 from this thread if anyone is searching, as well. No photos anymore, though.
Everything depends.
Nothing is always.
Old 06-26-2006, 05:54 PM   #12014
I run 3 degrees on the rear motor car, but never ran more than 2.5 on the front motor. At the nationals I even tried 4 degrees per side, I dont recommend that though
Old 06-26-2006, 06:54 PM   #12015
POOKYT's Avatar
http://www.jrxs.com/forums/index.php?showtopic=491
There ya go! The parts are not glued but as they were sanded down they had a glossy look on some. Imagine looking at the C hub and cutting the bottom off. then take that piece and stack it on topo of another C hub. The boss for the set screw is sticking down in most of the pics so it makes it a lil confusing. Hope this helps.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
