Old 06-09-2006, 04:47 PM   #11866
POOKYT's Avatar
Originally Posted by Johnny Wishbone
Anyone know the post # for the Weiss setup? Or a link?
Pookyt, when you are talking about the shims for roll centers, do you mean under the front and rear pivots of the front or rear end, or just under the degree pivot? (long bar versus small pivot block)
JF, what is O/S hub versus standard hub?
Thanks, JW.
I normally run the same number of shims under both the bars and the small blocks. If I have 2 under the bar , I will have 2 under the block as well.
The O/S hubs stand for Off Set. They are primarilly used for carpet to help the rear end rotate more in the turns. They are also what you use in the inside hole on the rear arms. Hope this helps man
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 06-09-2006, 04:53 PM   #11867
Johnny Wishbone's Avatar
OK, so the O/S stands for offset, then the stock would be 0 degrees? And what is the offset on the O/S hub? Yes, its all helping and thanks very much. JW
Still looking for the Weiss setup, anyone?
Old 06-09-2006, 04:55 PM   #11868
POOKYT's Avatar
Originally Posted by rcracingkid
You sorta contradicted yourself there, adding shims in the rear = more grip, adding shims in the front = less grip????????
Thanks for the hub info guys, i have always run offset for everything, and always all the toe in the hubs, maybe thats what my car lacks outdoors
Well.......not really. I look at it in the rear more as roll. In the rear the closer I get to having the hinge pins closer to the chassis, the harder the rear end wants to come around in the turns. As I raise up the rear hinge pins, this helps to keep the rear end under more control. On the front as I get the hinge pins closer to the chassis, the front of the car gets more aggressive.
The key is to balance the two. I hope this helps.
Brant
Old 06-09-2006, 06:02 PM   #11869
2-Bad's Avatar
Trader Rating: 24 (100%+)
Johnny,
The standard Hubs are available in 0, , 1, 2 degs rear toe-in.
The Off-set Hubs are also available in 0, , 1, 2 degs rear toe-in.
The only difference between the Standard and the Off-set is where they are mounted on the arm and the Off-set Hubs have an extended bearing housing to maintain the overall track wide of the car.
The Losi rear arms have two sets of hinge pin holes for the two types of rear Hubs. The standard hub needs to be mounted in the outer hinge pin hole on the arm. The Off-set Hub needs to be mounted in the inner hinge pin hole on the arm.
Hope this helps,
Regards,
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 06-09-2006, 06:47 PM   #11870
POOKYT's Avatar
WAZ UP PETER!!!!! Where ya been latley? Our thread has been a little slow as of late.
Brant
l
Old 06-09-2006, 06:51 PM   #11871
Thanks, Peter and Pookyt and Dwayne, finally got the Weiss setup and now I better check some hubs out as I think I may have mixed some parts up....DOH!
Old 06-09-2006, 06:53 PM   #11872
Don't woory Pookyt, with my mentally challenged knowledge there will be lots of questions to keep the thread going.
Old 06-09-2006, 06:58 PM   #11873
POOKYT's Avatar
LMAO Glad to hear it my man!!!
Brant
Old 06-09-2006, 07:24 PM   #11874
2-Bad's Avatar
Brant
l
Work is grinding my fingers to the bone..... I need a job like Todds... Just tinker with RC all day long......
Old 06-09-2006, 08:49 PM   #11875
POOKYT's Avatar
AMEN !!!!!!
Brant
Old 06-10-2006, 08:30 AM   #11876
Timmy_G's Avatar
Send a message via MSN to Timmy_G
when are you putting in your job application at Model Flight?
Losi, JR Propo ,Spektrum, Novarossi, AT Racing Fuels
Timmy_G is offline   Reply With Quote
Old 06-10-2006, 04:31 PM   #11877
2-Bad's Avatar
Very good.... did I forget to mention the MONEY I'll need long arms if I'm to live in Brisbane and work in Adelaide.....
Old 06-12-2006, 11:16 AM   #11878
TheCoolCanFanMan's Avatar
Was also at West London yesterday and very nearly TQ'd, but motor went a tad soft in the last 30 seconds as I did not have the brushes that I wanted to use and used F, Lines in my T,S, Atlas, The tyres were awsome, they did not fade at all, and it was megga hot, was well impressed with them but then I have done what NO one else has done to them!!!!! and its not cheating before anyone jumps up and down Just ask and I will reveal, some of the dudes already know, as I told them at the track yesterday, so im not keeping it hush hush, coz im not that sort of guy
Cheers Malc The-Cool-Can-Fan-Man
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 06-12-2006, 12:27 PM   #11879
Just tell us all what you did to the tyres then
losiboys is offline   Reply With Quote
Old 06-12-2006, 12:32 PM   #11880
simple really, just at them
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
