Team Losi JRXS
Old 05-24-2006, 05:17 PM
  #11806
POOKYT's Avatar
Yeah!!!! Do what Keef said man!!! LOL
TC4--Also make sure you are running the new arms or the BK brackets for the proper rates. Good Luck.
Brant
POOKYT is offline
Old 05-24-2006, 05:37 PM
  #11807
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Just try some POWER SOCKS!
J.Filipow is offline
Old 05-24-2006, 05:46 PM
  #11808
POOKYT's Avatar
WTH ????????
J.--You smokin that rag weed again???? LOL
Brant
POOKYT is offline
Old 05-24-2006, 06:16 PM
  #11809
tc4
tc4's Avatar
What do the new arms and th BK bracket mounts look like. Did team losi bring out the new arms and the BK mounts or are they an aftermarket product?
tc4 is offline
Old 05-24-2006, 06:32 PM
  #11810
The new arms are made by Losi. They're the same part numbers as the original arms but with an A at the end.
RcCzarOfOld is offline
Old 05-24-2006, 09:38 PM
  #11811
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Your my pick for 19t at Reedy man! Show em whats up!!!
Randy Caster is offline
Old 05-25-2006, 05:37 AM
  #11812
2-Bad's Avatar
Trader Rating: 24 (100%+)
They look like this....
2-Bad is offline
Old 05-25-2006, 03:32 PM
  #11813
Formula1fan's Avatar
Where do you guys get bearing kits?
Formula1fan is offline
Old 05-25-2006, 07:55 PM
  #11814
POOKYT's Avatar
WHOLLY COW!!!! Those are the first generation too! LOL Nice yellow wheels btw.
Brant
POOKYT is offline
Old 05-25-2006, 08:57 PM
  #11815
jrighter's Avatar
Default Please help!!
I dunno if it's because I'm exhausted or what but I've decided to give rubber tires a try and I'm in the process of putting the Numan setup on my car but having a issue. In the front only I cannot get my ride height below like 7mm. The shock collars are not even turned in a turn. New arms, low shock tower, super high front rollcenter (block in high position with .050 shims, etc.. Any clues? I'm not new to this so I've got to be missing something stupind. Do the shock retainers need trimmed down or something? Thanks in advance!
jrighter is offline
Old 05-25-2006, 09:00 PM
  #11816
Keith Billanti's Avatar
im guessing you didnt knock .125" off of the shock end when using the new arm?
Keith
Keith Billanti is offline
Old 05-25-2006, 09:05 PM
  #11817
jrighter's Avatar
ahh.. Nope. Didn't know.. THat may be the issue! Also, droop.. Numan setup calls for 2mm front and 4.5mm rear.. Is he measuring via uptravel or that actual droop gauge?
jrighter is offline
Old 05-25-2006, 11:33 PM
  #11818
2-Bad's Avatar
On the droop gauge I believe... this is what I've always done....
To get 2mm in the frt, you may have to file a bevel on the inside of the arm as the caster block stops the down travel of the arm in achieving the 2mm droop.
2-Bad is offline
Old 05-26-2006, 05:26 AM
  #11819
tc4
tc4's Avatar
With the Numan setup it is for a smooth, high grip ashphalt track and i'm racing on a rough, low grip track. Is there anything i should change? And also i am running a 540 motor so will i have to change anything because i'm going alot slower than a 7 turn motor?
tc4 is offline
Old 05-26-2006, 06:37 AM
  #11820
2-Bad's Avatar
The only adjustments I made from the Numan setup were:
12.5lb instead of 10.5lb rear springs, I felt the rear rolled over too far in middle to exit of a corner and consequently the rear would break away..
and depending on track grip I move from A-6 to B-6, to B-5 on the rear camber link progressively for more rear grip. I havenít found Iíve ever needed more then this to gain additional rear grip.
Hope this helps, PeterÖ
2-Bad is offline
