Old 05-05-2006, 04:52 AM   #11656
tc4
tc4's Avatar
Thanks for that mate
-Corally RDX PHI
-Johnson 540!
tc4 is offline   Reply With Quote
Old 05-05-2006, 04:44 PM   #11657
POOKYT's Avatar
You can also run the 1/2 deg. hubs on the opposite sides with the 2 deg. rear pivot and end up with 1.5 deg. toe in on the rear.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 05-05-2006, 05:15 PM   #11658
tc4
tc4's Avatar
Would it just be a waste of time if i put LCD's in the rear of my car? Also how do you tighten the diffs?
-Corally RDX PHI
-Johnson 540!
Old 05-05-2006, 06:08 PM   #11659
TLRacing
Todd Hodge's Avatar
Running LCD's in the rear will take traction away. I have tried them and have never liked them in the back.
To tighten the diffs. Just place a flathead screw driver into the screw head slot through the diff tube locking the screw in place. Now rotate the rear left tire towards you(clockwise).
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 05-05-2006, 08:41 PM   #11660
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
Am I going to get beaten with a wet noodle now? I just picked up an Xray FK'05 for foam tires on carpet. Don't worry, I'm not a total traitor, the JRX-S is my dedicated asphalt car.
Tony
RcCzarOfOld is offline   Reply With Quote
Old 05-06-2006, 01:46 AM   #11661
tc4
tc4's Avatar
Thanks for that T.Hodge
-Corally RDX PHI
-Johnson 540!
Old 05-06-2006, 02:46 AM   #11662
tc4
tc4's Avatar
I might be getting another JRX-S for spares if i have the money and i was wondering is there any parts that i should put from the spare car onto my racing one?
-Corally RDX PHI
-Johnson 540!
Old 05-07-2006, 04:29 AM   #11663
tc4
tc4's Avatar
Does anybody have a set-up or know where i can get one for a sort of tight and technical, low grip asphalt, outdoor track?
-Corally RDX PHI
-Johnson 540!
Old 05-07-2006, 05:52 AM   #11664
Use the Numan setup from Losi's webpage. That's pretty much the universal asphalt setup for the car.
http://www.teamlosi.com/pdfs/setups/JRXS/A3.pdf
There's a couple more that you could try also...
http://www.teamlosi.com/jrxs-page/asphalt%20index.htm
The Numan setup was working well for me on a low grip asphalt track last weekend. Track temps were very low and there was minimal traction to be had but my car was still pretty dialed even with the wrong tires.
Tony
Old 05-07-2006, 05:56 AM   #11665
2-Bad's Avatar
Trader Rating: 24 (100%+)
Yes, use the Numan setup, it's my base setup for everywhere. I've made these small changes to it: 12.5lb instead of 10.5lb rear springs and depending on track grip I move from A-6 to B-6, to B-5 on the rear camber link for more rear grip.
Regards,
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-07-2006, 08:20 AM   #11666
POOKYT's Avatar
NUMAN !!!!
Brant
Old 05-07-2006, 12:59 PM   #11667
scoyle's Avatar
Can someone please confirm some part numbers for the Numan setup;
The pistons are #56 part number LOSA5046?
The white O-Rings - the only ones I can find are red shock cartridge rings LOSA5014?
and I noticed that he has the pistons marked as drilled - what does this mean?
scoyle is offline   Reply With Quote
Old 05-07-2006, 01:05 PM   #11668
POOKYT's Avatar
Pistons are part # LOSA5341
Don't get too wound up on the white o-rings. The red ones are good too. When you see the pistons are "drilled", that means they took a #60 piston and drilled it with the #56 drill bit to have a #56 piston. Some like to do this as they will be assured as to the correct size of the hole. Again, I'm too lazy to do this so I simply run the # 56 pistons and am very happy. LOL I hope this helps you out man!
Brant
Old 05-07-2006, 03:24 PM   #11669
scoyle's Avatar
Brant
Cheers, thanks for the info.
Stephen
Old 05-07-2006, 05:54 PM   #11670
cooliomojo-CEBU's Avatar
im starting to assemble my jrxs and i lost the c clip used in the center shaft, is this necessary or could i just continue building the car?
cooliomojo-CEBU is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
