Old 05-04-2006, 05:07 AM   #11641
alb
Trader Rating: 19 (100%+)
Originally Posted by Keith Billanti
Gees.. you all are going to give me a big head.. haha..
Im going to pull out all the stops when i do my bodies. Well.. sortof.. basically, im going to get a new blade for my xacto.. haha.. thats all the stops...
the bodies i drew up for me are less "blingy". Few days.. ill post em.
Cant tell by the pic, but the black, is actually carbon fiber. Its a little dark.. but I found the perfect matt at walmart.
KB
Dude, you must be serious. You haven't bought a new blade in 5 years!
alb is offline   Reply With Quote
Old 05-04-2006, 09:19 AM   #11642
Default HELP SET UP
hi everybody, had the JRXS for a while now but i need some help!! I JUST CANT GET THE REAR END PLANTED. has any1 else had this problem
jordan
P.S I RACE ON AN OUTDOOR TIGHT,HIGH BITE OUTDOOR TRACK
jordys jrxs is offline   Reply With Quote
Old 05-04-2006, 10:24 AM   #11643
what setup are you currently using? also have you experimented with front and rear droop? On sunday i was using ben rayments setup, it can be found a few pages back and the rear end was stuck to the ground! is the rear end of your car loose at entry, mid, or exit of the corner? also the tyre choice can play a big role in grip
Niall is offline   Reply With Quote
Old 05-04-2006, 11:14 AM   #11644
Keith is Mr. chudy your former painter ? I havn't seen him in years.
Awesome paint job.
Chris Reilly is offline   Reply With Quote
Old 05-04-2006, 12:04 PM   #11645
Try more rear camber to get the rear to hook up. Also check droop. My jrxs is super sensitive to camber changes. At 1 degree the back is unpredictable and at two it is hooked up. Something to check.
JimMcClure is offline   Reply With Quote
Old 05-04-2006, 01:31 PM   #11646
SuperRooster's Avatar
Send a message via AIM to SuperRooster
I know, he asks me for one everytime I see him.
SuperRooster is offline   Reply With Quote
Old 05-04-2006, 01:51 PM   #11647
i was running ben rayments set up but it didnt really seem to work with my driving style
jordan
Old 05-04-2006, 02:07 PM   #11648
2-Bad's Avatar
Trader Rating: 24 (100%+)
jordan
I'm not familiar with the Rayment setup, but I predominately use the Numan setup with 12.5lb instead of 10.5lb rear springs and depending on track grip I move from A-6 to B-6, to B-5 on the rear camber link for more rear grip. I havenít found Iíve ever needed more then this to gain additional rear grip. Hope this helps, PeterÖ
JimMcClure,
I must remember to give that a try as well (camber from 1 to 2 deg)...thanks
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-04-2006, 02:33 PM   #11649
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Haha.,. i was going to say, AJ is my xacto blade supplier but he is 320 miles away.. guess I gotta drop the buck. GEEES.
CHRIS!! how ya been? Na, Chudy hasnt painted me a body in like.. well... before the last time I tried painting my own.. LOL.. ALBSLO was my painter.
KB
OUT
Keith Billanti is offline   Reply With Quote
Old 05-04-2006, 03:22 PM   #11650
Mr. Bella has some skills then. I guess it tough to paint with the family.
Congrats Al, Hope to see you around.
Old 05-04-2006, 03:23 PM   #11651
Keith I'm doing ok.
It's great to see you doing well. You have worked hard to get where you are.
Old 05-05-2006, 03:28 AM   #11652
tc4
tc4's Avatar
With the stock setup because the rear hub carrier is 0 degrees and the pivot mount is 2 degrees does that mean i have 2 degrees toe-in?
-Corally RDX PHI
-Johnson 540!
tc4 is offline   Reply With Quote
Old 05-05-2006, 03:58 AM   #11653
2-Bad's Avatar
Yes, 2 deg Total.... is my understanding
Old 05-05-2006, 04:23 AM   #11654
tc4
tc4's Avatar
Can the front pivot mount be swapped with the rear pivot mount?
-Corally RDX PHI
-Johnson 540!
Old 05-05-2006, 04:48 AM   #11655
yup, theyre all interchangable
OUT
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
