Old 05-02-2006, 02:05 PM   #11611
2-Bad's Avatar
Trader Rating: 24 (100%+)
I have mounted my fan on the side to ensure I get maximum airflow across the endbell (and also aids forward acceleration ). I use a 1 x 40mm fan, which blows more air, uses less current, and weights less the 2 x 25mm fans. It is mounted off lexan which allows it the fold if the car is hit from the side. I've been running this configuration for more then 9 months now and yes it has been slightly damaged from side impacts, but it is still working fine.....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-02-2006, 03:35 PM   #11612
Johnny Wishbone's Avatar
Default Fans
Has anyone thought about thermastatically controlled fan/s that would only cut in when they are needed? No drain on battery until you need it. I also wondered about a beeper or a led of some sort that would go off or on when a certain temp is hit just as a tuning/gearing thing for testing. Either one of these would be very simple circuits to make, durable and weigh next to nothing. Course its not as nice as telemetry but it would be alot cheaper.
Old 05-02-2006, 03:43 PM   #11613
I think with the very low current draw of the fans and the greater capacity of the new batteries you would not notice any diference running the fans all the time as opposed to thermostaticly controlled. You want the motor as cool as possible so running fans all the times would be an advantage. Also the added weight of the circuitry comes into play too. Just my thoughts.
JimMcClure is offline   Reply With Quote
Old 05-02-2006, 03:49 PM   #11614
TheCoolCanFanMan's Avatar
Not Bad 2Bad
But you could do with one over the motor can itself as then the magnets within the can will stop over heating, and help stop the motor from going soft
Cheers Malc THE CAN MAN
But a little vaunrable dont you think
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 05-02-2006, 04:00 PM   #11615
The fans we use have such a minimum amount of draw you would NOT feel it The wieght of the fans equate to 12 grams in total and push out 2.2 cmf.
The great thing is that we all have to add wieght to our light wieght Losi, so why not use it constructivley
Pops, Socal, Pookyt, Bill, even Todd himself has used the CCF and has liked it,
QUOTE I have received the items however I have not used them yet. The drill shaft is awesome. I have been trying to get TL to put extra holes in teh cvd's for quite some time but they will not because of cost issues. Now racers can do it themselves...very nice. The top deck is really trick...nice job.
UNQUOTE
The pic of the ICCF is of a early version as does NOT have the holes showing the extra akaman that was first ued by Todd (Todd's idea)
Sorry about the quality of the pic of the ICCF
If anyone would like more info, just ask
Team Losi JRXS-cool-can-fan-images-cars-058.jpg   Team Losi JRXS-drillshaft.jpg
Old 05-02-2006, 04:30 PM   #11616
2-Bad's Avatar
I have in the past put in series a bimetallic switch (setting 50 deg C), but due to its size and the round surface of the motor it was difficult to mount. Also, as Jim said the battery capacities have eliminated the current draw concerns over the recent years.
Old 05-02-2006, 04:42 PM   #11617
2-Bad's Avatar
Originally Posted by TheCoolCanFanMan
Not Bad 2Bad
As J.Filipow has said, and I agree that it's more important to keep the endbell cool. I believe (rightly or wrongly) that we are more at risk of de-soldering brush shunts & motor wires then motor fade. And as the fan is blowing over the endbell it is also partly blowing across the can as well. Without the fan, in the middle of the Australian Summer (60 deg C track temp's) I've de-soldered both brush shunts and the positive wire off motors during a race. With the fan I can run 7x1 as hard as I like, without motor fade, de-soldering, or dumping .
Old 05-02-2006, 04:52 PM   #11618
Here in the UK we are more on the side of stock and super stock therefore these motors take lot of punishment when it comes to keeping the power on most of the time, where as the modified guy's are backing of the throtel to get round corners (well they should ) and therefore I have to say that it is the stock and super stock drivers that are the ones that purchase a CCF
And there was me thinking you was ignoring me
Old 05-02-2006, 05:05 PM   #11619
2-Bad's Avatar
Yes you're probably right, stock drivers never back-off for corners..
Hmm, why would you think that Apologies if I have....
Old 05-02-2006, 05:18 PM   #11620
Tornado_Racing's Avatar
I have noticed running oval that our stock motors get REALLY hot over the 5 minute run and the fans are good for a 1/10 per lap after the 3 minute mark. Now that we will be going to 4200's I think heat will be an even bigger factor with summer just around the corner.
I still stand behind my theory of pulling hot air from the can vent holes and blowing air into the endbell cooling the com and brushes. When a motor runs air is blown out of the can vent holes so if fans are blowing that hot air back on the can IMHO it would cause the can to generate more heat and more magnet fade during the run. Blowing air over the com and brushes will help keep the brush from "baking" plus you are cooling the copper brush hoods and com as well.
Those are just my thoughts and experiences from testing the dual fans.
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
Old 05-02-2006, 05:22 PM   #11621
Apoligies not needed 2Bad, sometimes us limies feel we get left out
Corners, what are corners
TCCFM
Old 05-02-2006, 05:30 PM   #11622
We all have our different theorys, and see where your coming from Tornado Racing, so will give it ago over the weekend, as i not one for disputing the fact unless ive tried it myself Its just that I thought that motors have different characturistcs, some blow air out of the cans where some suck in air and blow it out of the other side, this is what I have found on the motors I have tried, but as I say I will give it a whirl so to speak
Old 05-02-2006, 05:34 PM   #11623
Kool deal, let us know your findings.
Unless it's a reverse rotation and wired backwards all motors will push some form of air through the vent holes.
Tony Moffre
Old 05-02-2006, 06:17 PM   #11624
Trader Rating: 70 (100%+)
Where can i find Keith b carpet setup?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 05-02-2006, 06:26 PM   #11625
POOKYT's Avatar
I love the CCF unit and either pulling or pushing air is a benefit over NO fan!!!! The CF top deck is of factory quality or better!. Besides I am lazy and with this unit all I had to do was bolt it on and hook up my switch! With the crazy X-Ray drivers at my home track, a side mounted fan is NOT an option!
P.S. Malc........Do I get a free drive shaft drill thingy now??????
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
