Old 04-23-2006, 06:54 AM   #11536
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by tc4
So can you use corally plugs that are soldered onto the battery or do you have to get another battery bar and bend it over and solder the plug onto that?
See the jpg below, this is what I and many have done. This configuration works very well for all my car/buggy/truck.
The spur/pinion combination is limited by the size of your servo and/or if you run a servo-saver. With my Hitec servo and a Kimbrough medium servo-saver I'm limited to 128/40 before the motor rubs on the servo horn.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-23-2006, 10:59 AM   #11537
Greenbandit's Avatar
Ok, I need some advice. I ran my JRX-S yesterday for the first time since last season and the car was just no good. The car has loads of traction, but I could not get it to turn. Pushing like crazy. I am running the Neuman set up with the following changes: High roll center, rear link in the #5 position (middle hole), and 6 degree front caster blocks. I also tried both a front one-way and a diff with little or no difference. The one-way had slightly more off power steering. I am running 19T with cs-27 spec tires on high grip asphalt. Also running a Stratus 3.0 AP body. Needless to say, I could not carry any corner speed at all. Any advice on what to change to get it to turn? Thanks in advance.
Todd Daly
Greenbandit is offline   Reply With Quote
Old 04-23-2006, 11:20 AM   #11538
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I alos run the Numan setup but I use camber link #3 in the rear to help get the car to rotate and use 0 degree rear hubs and just the 1 degree rear toe block. For are track I also had to go to the 12. spring in the rear. Each one of these adjustments made the car better and turn more. I also went to .50 rearanti squat as well. In the front the only thing I have been messing with other than the 6 degree front caster blocks has been the I run a 2 degree front pivot block to sweep the front arms out more like they do on a few other brand cars to get more aggressive steering.
Might want to try a few of these and see if any help you out.
ST Racing Concepts (STRC)
Old 04-23-2006, 12:15 PM   #11539
Thanks Wyd. I will give those changes a try.
Todd Daly
Old 04-23-2006, 12:48 PM   #11540
wyd
Tech Legend
wyd's Avatar
One other thing that I wanted to try was a Protoform all purpose Stratus as well. Are track has massisve traction and sometimes the Mazda 6 is a little more than what we need. Some guys have had success at are track with the Stratus.
Old 04-23-2006, 01:46 PM   #11541
POOKYT's Avatar
I have also seen several people use the Parma Alpha body on the asphalt when the traction is too high. Overall, it is a very neutral body. Many of our novice guys will run this body as at our track, it has been a good chioce,
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-23-2006, 06:13 PM   #11542
tc4
tc4's Avatar
Would i be pushing it if i used 128t/56t or would it be better to go with 118t/51t?
-Corally RDX PHI
-Johnson 540!
tc4 is offline   Reply With Quote
Old 04-23-2006, 06:33 PM   #11543
Mike Haynes's Avatar
128 / 48 is the most that can fit in the standard mount (motor srews run out of room to slide), you will need a smaller spur to gear higher.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 04-23-2006, 06:58 PM   #11544
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
128/56?!?! What kind of motor and what size tires? That's a ridiculously high rollout. I'm running 128/34 with CS27 premounts for a 1.14 rollout with an Atlas 19T... The motor comes off the track at about 155 degrees and I have gobs of top end with stump pulling punch out of the corners. I can't think of any situation where you'd want THAT high of a gear... That's insane...
Tony
RcCzarOfOld is offline   Reply With Quote
Old 04-24-2006, 12:58 AM   #11545
tc4
tc4's Avatar
I'm gearing it for a 540 Johnson motor.
Also do you need a spur gear adaptor to run the team losi 90t 48pitch spur gear?
-Corally RDX PHI
-Johnson 540!
Old 04-24-2006, 04:44 AM   #11546
TheCoolCanFanMan's Avatar
Originally Posted by scoyle
Malc,
Can I ask what 19t motors you and Ben were using and what gearing?
Cheers,
Stephen
Hi
I was using a EA Atlas @ 5.1 I belive I was on 118x44 but he does not sell them any more (good old Ernie P, NOT) but am now using Team Screams Atlas's they are very quick to.
Cheers Malc THE CAN MAN
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 04-24-2006, 05:12 AM   #11547
Originally Posted by J A M I N
CoolcanFanMan/Malcolm...who's ya mate!? LOFL!
Ye old 'BALD EAGLE' as if you didn't know RAOTFLMFAO
Malc
Old 04-24-2006, 05:26 AM   #11548
Great action shot of my JRXS at Bedworth, UK.
http://pasadena.directrouter.com/~cl...b_IMG_2344.JPG
Mine to
But I do not know how to show the pic, you clever boy Ben
Old 04-24-2006, 05:39 AM   #11549
Tony
That's a lot of heat your getting off your motor, why dont you use a Cool-Can-Fan top deck on your car, Ask Pookyt what his thoughts are about it
Old 04-24-2006, 05:44 AM   #11550
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
