Old 04-22-2006, 05:26 PM   #11521
Does anyone know if Losi will produce the drive shaft version they were talking about a year ago?
JunotFranco is offline   Reply With Quote
Old 04-22-2006, 05:52 PM   #11522
POOKYT's Avatar
Originally Posted by tc4
I've heard that you have to re-solder your battery packs for them to fit in the car, is this true? Also can you run corally connectors that are soldered onto the battery or do i have to get another battery bar and bend it over and solder the plug onto it?
On my car i took the bars for the wire leads and angled them in towards each other. I also turned them to stick outside or point to the outside of the car so I could solder the leads easier. I have seen several guys do this same thing but have the flat part angle to the inside of the pack and then solder the orion style tube to use the Corraly/Orion/ who evers tube style battery connectors. Truth be told I would use the tubes but I am too lazy to convert my stuff! LOL I hope this helps you out. Ask if you have any more questions.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-22-2006, 05:53 PM   #11523
POOKYT's Avatar
Uh..........Never heard about a shaft version. Sorry
Brant
Old 04-22-2006, 09:03 PM   #11524
robsxxxs's Avatar
i have a quick question about the neuman setup. when it says to put 2 o-rings above the white bladder can i just use the black bladders and get the same result?
AE FT TC5
Losi 8ight B
Losi 8ight T
Losi XXX MF2
AE FT T4
Tamiya 415 MSX
Losi JRXS
Losi XXXS
robsxxxs is offline   Reply With Quote
Old 04-22-2006, 09:05 PM   #11525
tc4
tc4's Avatar
So can you use corally plugs that are soldered onto the battery or do you have to get another battery bar and bend it over and solder the plug onto that? Did you have to re-solder your packs to get them to fit?
Also does the XXX-S spur gear adaptor work with the JRX-S?
-Corally RDX PHI
-Johnson 540!
tc4 is offline   Reply With Quote
Old 04-22-2006, 10:05 PM   #11526
Yeti35's Avatar
I don't know what you mean about resoldering the packs to fit but you will have a hard time making them fit if you double shrink wrapped your cells and shoe gooed between the cells. This only applies to the 38's or larger cells. Best way for Corally plugs is to bend a bar and solder the barrel on it and have it lay close between the cells. That is how I have mine done.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 04-22-2006, 11:17 PM   #11527
tc4
tc4's Avatar
Thanks for that. Does anybody know if the spur gear adaptor from the XXX-S will fit on the JRX-S?
-Corally RDX PHI
-Johnson 540!
Old 04-22-2006, 11:19 PM   #11528
Randy Caster's Avatar
Trader Rating: 46 (100%+)
No, PRS makes one if you'd like to use aftermarket spur gears on the JRXS.
Old 04-22-2006, 11:20 PM   #11529
The 2 o-rings over the white bladder will have quicker rebound than the black bladders.
Old 04-22-2006, 11:26 PM   #11530
tc4
tc4's Avatar
Does PRS make spur gears or the adaptors for the JRX-S?
-Corally RDX PHI
-Johnson 540!
Old 04-22-2006, 11:49 PM   #11531
Both.
Old 04-23-2006, 02:25 AM   #11532
tc4
tc4's Avatar
With the JRX-S can you fit a 118t spur gear and a 51t pinion gear all in 64pitch on the car without it rubing on the chassis or is it to big?
Sorry about all the questions but i just want to know some things before i buy a JRX-S.
Thankyou
-Corally RDX PHI
-Johnson 540!
Old 04-23-2006, 04:10 AM   #11533
Tornado_Racing's Avatar
I run a 108/51 on my JRX-S for the oval. So yes you can run a 118/51. Here are a few links to the adapter and spur for the JRX-S:
Spur Adapter Assembly
Spur Adapter Only
Pro-lite 64 Pitch TC Spurs
64 Pitch Pinions
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
Old 04-23-2006, 04:35 AM   #11534
tc4
tc4's Avatar
So can the motor mount accept the big gears?
Thanks for all the help guys i really appreciate it.
-Corally RDX PHI
-Johnson 540!
Old 04-23-2006, 06:40 AM   #11535
Yeti35's Avatar
The stock spur in the kit is 128t so you will have no issues with rubbing or anything.
22 3.0SR
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
