Old 04-19-2006, 07:50 AM   #11476
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by FERNANDO
also who makes a spool for the car..??
You will need to make your own spool up using the stock diff. Most use sandpaper to make diff rings and Losi has some new rings coming out to make spools with.
ST Racing Concepts (STRC)
Old 04-19-2006, 09:03 AM   #11477
windix60's Avatar
Fernando,
The bearing you need are used for the steering rack pins on the off-road BK-2 buggy. LOSA-6912
windix60 is offline   Reply With Quote
Old 04-19-2006, 09:46 AM   #11478
windix60...awesome thanks...
FERNANDO is offline   Reply With Quote
Old 04-19-2006, 12:54 PM   #11479
OK chaps, I need a couple of LOSA4253 (sway bar plastics), but I cannot get them over here in the UK
Where is the best place in the states I can mail order these from?
Horizon Hobby wont deliver to the UK....
Team Losi XXX-CR | XXXT-CR | JRXS-R | JRXS | XX-CR | XXT | XXT-CR G+ | Mini-8ight | TLR22 | TLR 22T
J A M I N is offline   Reply With Quote
Old 04-19-2006, 12:55 PM   #11480
Originally Posted by TheCoolCanFanMan
brakes, what are brakes
Yea have to admit, you coming up to me and congratulating me on a second place in the second A, from your goodself made me real proud, for someone as good as you to say that.
Why'd you go early and put me under presure on the last run as I was then unaficially on pole you swine and binned it on the first corner so as every one else would use me as there brakes, still least I got another 9 laps in before my ball stud got ripped out of my steering arm and was getting back from 10th to about 4th when that happened. Still was a great day for the Losi eh, you never know sponsorship maybe looming for the old man yet I will have a chat with the 'Bald Eagle' on that score
Cheers Malc THE CAN MAN
No worries Malc, I thought you did really well. 19T is alot more competitive this year...
Old 04-19-2006, 12:56 PM   #11481
Originally Posted by Bigger Brother
Well done Ben & Malc
Are you using the rear tower as standard, or in front of the rear bulkhead?
I'm gonna put that setup on my car now as my starting point for outdoors. Just need to finalise my indoor one and get me some horsepower and I'll be sorted
Oli
Rear tower in the standard position at the back, but I am running a rear tower on the front also so I can get more top link positions.
Old 04-19-2006, 01:56 PM   #11482
JRXS_chris's Avatar
This one's for Karl (berger) and POOKYT
JRXS_chris is offline   Reply With Quote
Old 04-19-2006, 03:30 PM   #11483
Send a message via MSN to Bigger Brother
Cool, thanks. I'm assuming shock hole positions were re-drilled to match that of the original tower? And you were using BK arms front & rear too?
Many thanks, really want to get some tarmac racing in soon, before I go back to Uni in May
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 04-19-2006, 03:43 PM   #11484
JRXS_chris's Avatar
Sorry to butt in here!
If you use the normal front tower as a template you will end up overlapping the holes and it will A) look crap and B) not work!
I drilled bang in the centre of the two holes for the new hole.
There is the other option of the funky double front shcok tower, theres a pic knocking about somewhere on here...!
Old 04-19-2006, 03:51 PM   #11485
2-Bad's Avatar
Trader Rating: 24 (100%+)
http://www.kthobbies.com/shop/produc...af2270c230edff
https://www.ssl-stormerhobbies.com/c...=ns&pn=LOS4253
Regards,
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-19-2006, 03:52 PM   #11486
Mike Haynes's Avatar
Chris, when you want to drill new holes to match the normal front, i suggest you use some ca glue and ca kicker to fill in the holes in that area that you need to drill.
Just put a little kicker in the hole, a few drops of ca, and drmel it flat with the carbon fiber, when you drill the hole it will be plenty strong and you can't really tell it was filled in.
That should help ya out.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 04-19-2006, 04:12 PM   #11487
Thats why mine have never came ive had them on order with helger for about a month now. lol
looks like i will have to get them from the states aswell but the postage is really expensive usually
Niall is offline   Reply With Quote
Old 04-19-2006, 04:47 PM   #11488
POOKYT's Avatar
OK Your good to go! LOL
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-21-2006, 12:42 AM   #11489
2-Bad's Avatar
Guys,
Need some advice on what is causing this to happen to my tire....
This is my left front tire and it's had 6 packs... Tire is a Sorex 36 with a Xenon Black insert. The other tires are fine. It looks like it's overheated, but usually it seems to have peeled from the centre line of the tire....
Old 04-21-2006, 08:52 AM   #11490
Still Bill's Avatar
Originally Posted by 2-Bad
Guys,
Hi 2-Bad,
Overinflated tire?
Seriously, because most tracks are setup to run clockwise, the left side tires get more load than the ones on the right. Additionally, with the weight transfer going to the left front tire when turning and slowing, always makes that the most burdened tire. Same applies to the foam tires I use for carpet racing.
Assuming that you are running in very warm conditions, I would suggest rotating the tires often to spread the wear.
Question... Which hole in your front hubs does your steering linkage go to? Are you running a diff, spool or one-way?
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
